87 octane
Popular Reply
05-11-2021, 07:41 PM
Am I missing something here? Won’t the ECU prevent any detonation/damage while running 87 Octane? It’s a computer controlled engine.
Just drive gentle & easy, stay out of the gas the best you can until you can fill back up with premium (91+).
The following 4 users liked this post by Kracka:
E-Ray, 3LZ, ZER, LIFT
Received 9,640 Likes
Quoting the Owner's Manual, pp204
"Use premium unleaded gasoline meeting ASTM specification D4814 with a posted octane rating of 93 — (R+M)/2. If unavailable, unleaded gasoline with a posted octane rating of 91 may be used, but with reduced performance and fuel economy. If the octane is less than 91, the engine could be damaged and the repairs would not be covered by the vehicle warranty."
Yep detonation recorded and GM can tell! In a real pinch might drive in Manual Mode, no V4 and keep rpm above 2000 maybe 2500 AND drive like you have a raw egg between your foot and the throttle!
The following 4 users liked this post by JerryU:
Why not just add octane booster?
hamta (05-11-2021)
If you want to go the octane booster route (most of which is junk), you're better off adding a gallon or two of E85. Cheaper & more effective...
The ingredients in octane booster can also void the warranty. Most contain some items that are in the prohibited fuels section of the manual.
I've avoided buying cars, or the 6.2 in a pickup due to the cost of super.
But you can be sure super goes in my current and future Vette!
IMO you're asking for trouble at some point not using super.
I think he is referring to the pipeline issue and lack of available gas. 87 may be the only option available for many folks over the next couple days/weeks.
The following 3 users liked this post by thill444:
Octane boost is tricky, with their description. Some say something like "will raise octane up 4 points". This does not mean your 87 octane is now 91, it means your 87 octane is now 87.4. Make sure you get one that says raises your octane by numbers, not points. I buy gallon jugs from a company called Klotz, for my 69 Oldsmobile, that still needs leaded gas. Although they do have unleaded options.
Also, look up Sunoco race fuel sellers. Comes in 5 gallon cans, so you can boost up the average. Just bought 5 gallons of 116 octane for 80.00 (leaded and unleaded options, so make sure you grab the right one)
I cannot speak to voiding of the warranty though, as mentioned above. Weigh your risk.
Hope all turns out well.
Just put 91 in it and forget about octane booster. I know gas is high but that small difference is worth it and will keep your engine problem free (knock on wood) for the most part. That could be a very expensive lesson if something happens to that engine and GM refuses to cover it. And they can tell if you used lower octane gas from the diagnostics.
wfoZ06 (05-11-2021)
Received 11,607 Likes
I just looked up the Klotz product. It raises a related question. I also read the stuff in the manual about the danger of certain fuel system additives. The Klotz product says it also will act as a fuel stabilizer for long term storage etc. So...what about fuel storage products? I use fuel stabilizer in all of my other collector cars because over the winter month they dont get driven so much. And, in 2020, nothing I have got driven much, so I used fuel stabilizer in my regular cars too. Will that be an issue for the C8? What, if any, fuel stabilizer products are safe, or approved, for use in the C8? I dont know what is in stabil, but it smells like it has hydrocarbon type stuff in it. Star-tron is claimed to be "enzymatic". Maybe its safer?
Sorry...I live in Texas where we have lot's of fuel at all octanes. That's a tough one.....if it were me I'd park the car and not drive it until 91 returns, but I know that is not an option for everyone. If you have to then just drive is as few miles as possible. I had an SL-500 that was very clear on the gas door not to put lower octane in the tank or engine damage can occur....but in the owners manual it stated in an emergency you could drive it up to 50 miles on lower octane....they said no more than 5 gallons in the tank.
I know this sucks....but that's an very expensive car that you waited a long time to get...and an engine swap could take a very long time to get done if that one goes sideways.
Red Mist Rulz (05-11-2021)
Chevy has to put it in the manual to CYA. I’d be willing to bet a good sum that a tank of 87 isn’t going to hurt it, especially if driven responsibly.
Id expect it may ping a little under load, no different than getting a bad or old batch of 91.
The following 6 users liked this post by TXFlyGuy:
ajmart85 (05-14-2021),
hokieZ (05-11-2021),
KitGerhart (10-22-2021),
mikemote (05-13-2021),
RussM05 (05-14-2021),
and 1 others liked this post.
I'd park it before I'd run 87 octane, especially in hot weather.
mracer14 (05-12-2021)
