Full Length Side Skirts Without Vertical Wing
Is any company making full length C8 side skirts without the vertical wing? Looking for flat, full length side skirts in carbon flash.
Thanks.
Thanks.
The following 2 users liked this post by Driver_WT:
dreamr616 (03-14-2021),
iflex2fitness (03-12-2021)
zcobra1 (03-12-2021)
ea327 (03-17-2021)
Trackfecta
I just ordered these. Yes it’s carbon fiber, pricey, but great quality, crazy lightweight, and looks good. Just another option.
Racing Sport Concepts
rsl2715 (03-11-2021)
Moderator
Available in CF and carbon flash: https://www.quintenracing.com/produc...s-carbon-fiber
I got mine the other day. The front splitter was a very easy bolt on. I haven’t installed the side skirts yet because I’m waiting to get my paint correction and PPF on. There is some double-sided tape on them and you have to drill holes in the bottom of the car and rivet the side skirts on.
The quality is absolutely perfect on mine. I went with the carbon flash finish.
Looks great but but they'll have to be dusted off every 10 miles...
These lines off or is the door ajar?
C8forT (03-28-2021)
The install was easy. There are pre drilled holes in the skirts and some tape to help hold them in place. you have to drill several tiny holes under the bottom of the body panel and then use the supplied rivets. it took me probably 5 minutes to do each side.
