HTC engine cover
HTC engine cover
Has anyone driven with the engine cover off? I was wondering if the heat will mess with top when its down or the back panel when the roof is up.
Just would make it easier to work on and also capable of seeing the motor when top is goin up or down or at a show.
I'm sure it's there for a reason.
The one on my HTC is staying put.
Look at the bright side. If you pickup a Pizza, you can stick it on top of the Engine Cover to keep it warm on the drive home.
Jeffthunbird (01-31-2021)
Yes, it will mess up your top which is why they put the engine cover on.
What "work" are you going to do from the top that requires taking the cover off? Oil and coolant are accessible with the cover on. Air filter access is through the trunk. Plugs, wires, coils, belts, alternator, water pump, filters, drain plugs are all accessed from below.
Here is a video of how to install
The following 3 users liked this post by Silamanajik:
Not only would you need a heat shield (maybe just to lay under or over the transparent cover), but to show the car you would have to deal with dressing up an engine that was designed to never be seen. From the pictures I have seen, the HTC engine is not particularly "pretty" to look at, nor does it need to be....
Some interesting challenges to overcome...
Received 1,530 Likes
Unmodified C8 of the Year 2021 Finalist
Received 11,614 Likes
Hopefully the new intake is attractive, the motor without the decorative cover that comes on the coupe looks like the Borg, pretty ugly.
/Bear/ (01-30-2021)
You can fix this problem by installing Dzus 1/4 turn fasteners like they use on race cars and aircraft. Then you can have the cover fully seated and when you want to take it off, just quick turn all the Dzus fasteners and have it off in 30 seconds.
Here is a video of how to install Installing Dzus Fasteners - YouTube
Those are pretty cool, but it looks like it would be quite a bit of work (drill, dimple, rivet) to install them, and it could take some trial and error to get a tight seal depending upon the thickness of sheet metal there. It's possibly easier to just use the 18 screws it comes with, as long as you don't drop any into the engine bay!
I'm less concerned about seeing the engine and more concerned about how I'm going to get a supercharger on an HTC... they say ProCharger has a supercharger near raedy, but I've not heard anyone say it'll fit on an HTC.
I thought a saw a post in the tech section that they are making it fit the HTC also.
Heat is one issue however the racket that engine and transmission make is very unpleasant. That’s the real reason that insulated cover is there along with fire suppression.
