IDing a 1LT
Post #6 wins hands down. It's the easiest to spot from 10 or more feet away and from most angles.
True, but the "camera mirror" is almost a safety necessity on the C8 coupe. Rear visibility is very bad with only the standard traditional rear view mirror.
Foosh (12-25-2020)
I never have and never will "speak as an authority" on the C8. However, certain things are blatantly obvious based upon seeing it, sitting in it, having owned similar platforms, and listening to owner and reviewer comments.
Phil1098 (12-24-2020)
Received 11,610 Likes
22c8zo6 (12-24-2020)
Side-view mirrors
- To adjust the driver’s side-view mirror, place your head against the left side window and set the mirror so you can just barely see the side of the car in the mirror’s right side.
- To adjust the passenger’s side-view mirror, position your head so that it is just above the center console. Set the mirror so you can just barely see the side of the car in the left side of the mirror.
Side-view mirrors
