First time removing roof
And it was a bear. I have the transparent roof and it weighs a lot more than I thought. Then I tried to put the roof back on. That really was hard to do. I attribute it to the new weatherstripping but I know the roof stays on from now on.
bodak1 (10-12-2020)
Popular Reply
10-08-2020, 12:22 PM
Trade it in for a HTC
The following 5 users liked this post by Racer86:
919cw313 (10-08-2020),
Losbot (10-12-2020),
roadsterboy (10-12-2020),
Yammyhaha (10-08-2020),
z edge (10-08-2020)
The following 14 users liked this post by Thunder22:
Big Lebowski (10-08-2020),
ChevyChad (10-08-2020),
DNAST1 (10-08-2020),
DoubleMint (10-08-2020),
Gotta-Qik-C7 (10-12-2020),
and 9 others liked this post.
Received 4,383 Likes
Or you could start doing weights . Me personally, I would just leave the roof in. But since my wife put the deposit down on the car, and she has always wanted a convertible, we are getting an HTC. It is the best of both worlds, she gets the open top motoring she wants and I don't have to work out!
Received 4,116 Likes
2020 C8 of the Year Finalist - Unmodified
I think the transparent one is much heavier.
A lot of this is about leverage. With a bit of practice it can be a bit easier but to be honest, I think targas are better off removed with 2 people to avoid a mishap.
Received 2,684 Likes
2018 C6 of Year Finalist
The following 2 users liked this post by 919cw313:
Matthew_C8 (10-12-2020),
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Sir Nuke (10-12-2020)
NCM Lifetime Member
I had a C7 Z06, and now the C8 w dual carbon fiber roof and transparent roofs . I think the transparent is the lightest of the group.
Dimensions are very similar.
I have noticed the roof rattles a lot on the C8, needs to be adjusted
Saw on one of the You Tubers where the CF Top weight 20#.
Hit the gym... it's not that hard. Or go order a HTC.
Received 4,023 Likes
"14 lbs - Carbon Fiber Top
15.5 lbs - Body Color Painted Top
17 lbs - Transparent Top
For comparison, the C7 Carbon Fiber Top weighs in at 16 lbs."
https://www.corvetteforum.com/forums...l-weights.html
Lit (10-09-2020)
Received 5,239 Likes
Yes, it can be cumbersome, especially for a small person. So, why not simply get someone to help, since most don't seem to remove and install it all that often?
Navigator
took a little getting used to
I have the transparent and it takes a little getting used to. I'm always cautious when locking the top down or unlocking in the trunk area. The amount of push or pull, to lock in or unlock, causes some trepidation so as not to damage anything. I will engage assistance if available but have now removed and replaced the top 10+ times and so far so good.
