Burning smell after driving
After a long drive about 50 miles there is a burning smell like brake pads overheating or the smell you get from a manual clutch slipping. Not sure if anyone else has noticed this. My car has about 200 miles
1 LT base model NNP exhaust.
The following 2 users liked this post by pauly1119:
Avanti (08-31-2020),
Red C8 of Jax (10-15-2021)
This is normal on a new car. You will also experience this on a well broken in Corvette when run hard.
Check for signs of any leaks under the car.
They do it when new. Gradually gets better. After I drove home for the first time I had to look around the engine bay to see if anything was on fire. At 3000 km there's still some smell when hot.
Mark Carlson (10-15-2021)
Mine smelled like something was burning and had some smoke coming off of the engine for about the first 300Km's. I believe it was just the brand new exhaust. Its totally gone now.
Modified C8 of the Year 2021 Finalist
Yep, totally normal. Things like grease on the outside of the engine or smeared on the exhaust gets burned up.
I'll note this is also really prevalent on the new Mazda's I buy.
That is the clutch slipping..............
Totally normal... it's all the glue in the chassis heat cycling. It's very strong for a few days and goes away after 1,000 to 1,500 miles.
Perhaps I'm just sensitive, but even after almost 6 months there's still a distinctive hot engine aroma that comes off mine.
In any case, they would not be the cause of odors out of the ordinary.
speedlink (08-31-2020)
I think it's okay; you don't have to worry. If you are very worried about this, you can give the car to the service for diagnostics; the specialists will tell you for sure if there are any problems. However, I, like other people on this forum, think that everything is fine. If this smell bothers you or you are too sensitive to it, you can use in the salon, as this tool removes such specific odors well. I use it myself when my wife smokes in the car, and I am happy with how fast it works. I hope my comment will help you, good luck
A lot of manufacturers use rust preventatives like Cosmoline on various parts, which creates a distinct smell when burning off. BMWs built overseas were notorious for the burn-off smell.
