Dealer > 2 post lift crash
OnPoint (06-01-2020)
#162
Cars falling off lifts at the dealership happens all the time. Sucks.
My brother in law had a brand new Chevy 2500 HD pickup that fell off the lift at the Chevy dealership. He dropped it off for an oil change. Hours later he called and said can I pick it up, first they said it was not ready, then he called again and the truth came out. Smashed up the whole rocker panel and side of the truck. Sad thing is the dealership tried to hide the fact that it was smashed up and had to be pushed before the truth came out.
I hope for the owner the dealership makes it right and replaces his C8
Shaka (06-02-2020)
#163
Received 1,609 Likes
St. Jude Donor '16-'17,'22,'24
I have a feeling, this won't be the last time we see this happen to a C8.
But probably the last time it happens at that dealership.
Shaka (06-02-2020)
#164
You still aren't getting it, look at this picture from the video, the arm supporting the front is almost straight out from the lift and the rear one is at about a 45 degree angle all extended. It puts WAY too much weight away from the center of the lift. Cg is one thing, where it is in relation to the center of the lift is the problem.
#165
No it is not. That stresses the lift and can cause the lift to fail. The lift did not fail, the car was lifted at the wrong lift points. Probably also was positioned wrong on the lift (like you say, I agree) but the lift stayed straight up and did not fail. The car was unbalanced and when the front wheels came off, that was enough to send the front end up. If the lift collapsed (tipped back) I would say that is why the car fell.
ticat928 (06-02-2020)
#166
Rick Conti's Corvette Technician almost did the same thing...notice that he thought you were supposed to use the wrong lift points at first.
Start the video at 6:26...
https://youtu.be/GWIw6ciMQC4?t=386
He STILL is using the wrong point for the rear. His assumed front hole he pointed as was wrong as well but he got the front arm correct.
#169
Yes it would've. The tech used the wrong jack points and lifted the car. It did NOT slide off. The front wheels and bumper were removed. That is when the front of the car tilted up and then slid off. The 2 post lift was not compromised and the dealer will continue using it as is. Backing the car on that lift would reduce the strain on the lift posts, but would not prevent the tip of the car. This was NOT an equipment failure, it was a human error.
Xact (06-06-2020)
#170
I don't understand the question. If the car was the other way around in the picture with the goofball, The arm placement as they are world be correct for both a symmetric and asymmetric 2 post lifts. The Cg must be no further from the posts shown on the asymmetric lift dwg. and directly in between the posts on a symmetric unit. The only way you will achieve that would be to back the car in. You would then be able to open the doors. An asymmetric 2 poster is a very dumb idea.
#171
I'm still curious what those small jack stands and the wheel chock were for in the picture. Did they get put there after the accident?
#175
#176
Received 9,530 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
I'd still like to know what really happened - like from a witness, or second hand from a witness - not from one of us keyboard warrior know-it-alls. But your explanation, and others have said the same, is what makes most sense to me. If that is the case the main contributor of the failure was not supporting the vehicle using a jack stand when removing equipment.
#178
#179
