The 2nd snapped axle I've seen!
I'm guessing we'll see more of these snapped axles when the Z comes out.
The following 4 users liked this post by Second Vette:
I am a expert on rebuilding axles as I work part time with one of the best axle and driveshaft re builders on the east coast. What exactly is snapping on these axles. There are only 3 parts to a axle, the shaft , the race and the cage. It is almost impossible for the shaft to snap so that leaves two.
The following 2 users liked this post by Let It Ride:
ArmchairArchitect (05-08-2020),
BIG ATLANTA (05-08-2020)
Stock! or running some nitrous?
C8Jake tanks for the usual dumb comment! 2,700 C8's on the street now. 1% of people are probably the only ones pushing the C8 which brings that 2,700 number down to 27 C8's that are being pushed. That's a 4% failure rate of a sports car being driven like a sports car in about 3 months or so after being shipped. Add wear and another 9 months and we'll probably be looking at a 12% failure rate.
Add more horsepower and the number goes up even higher. Hard to believe that after "years" of testing GM didn't notice that their axles were failing....
The following 2 users liked this post by C8Jake:
CorvettoBrando (05-11-2020)
Received 11,621 Likes
gurneyeagle (05-08-2020)
Breaking axles is cheaper then breaking tranny like the GTR did back then?
The following 6 users liked this post by CDNZR:
keagan (05-08-2020),
Kodiak Bear (05-10-2020),
Shaka (05-08-2020),
ticat928 (05-08-2020),
and 1 others liked this post.
You left out the rest of the story. Nissan said it was because the owners used the factory installed launch control and that was abuse (shouldn't have been used) so the $20k gearbox was on the owner. Then later they lowered the launch RPMs. Peeled the splines off the input shaft like an onion.
The following 3 users liked this post by Phil1098:
GM has no cause for concern, unless this happening on OEM tires with correct pressures
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
Yeah, maybe the owner should realize it's designed to be a sports car and not a drag car. Launching at the drag strip with low tire pressures and the grippy track surface puts way more stress on the car than launching on the street with recommended tire pressures.
What I don't want is GM beefing up these axles and adding the worst kind of weight to the car: rotating and unsprung.
The following 2 users liked this post by ArmchairArchitect:
SteveSoCal (05-09-2020),
The following 3 users liked this post by Shaka:
We don't have all the info in the least, they may have had low tire pressure on drag radials and coming out of a water box and then sudden hook on dry prepared concrete. Just go to Youtube and watch the videos of all the Challenger diffs exploding in this same way as described. There is nothing made that can't be broken given enough abuse.
What ever it ends up being you can guarantee that it will be expensive and a PITA to get to. If you need to have a weak link, I could think of worse ones than the axle shaft.
not the tranny just more tire smoke....lol...Z version and 2021 models will be upgraded if needed...pay to play also comes to mind...Mass produced street car (except for this year) not dedicated 1/4 miler...jmho
