First mechanical issue
#41
if they always used 100% perfect parts we would never have anything to modify, or do
I think the engineers purposefully put such items as plain looking shifters & other 'cheap' parts in order to facilitate the American hot rod part of the brain which can only come on and be satisfied when 'upgrading' certain things about ones ride...
because its about its the journey
#42
I did not notice any inconsistencies in braking feel other than the one time I forgot to put it back in track mode between sessions. I entered the track in tour m and the brakes definitely didn't react quickly. But that was my fault not the cars. It was working as designed.
CorvetteBrent (05-04-2020)
#43
There's no wear on the axle and the only thing here is something caught that boot,debris on road and drove over it and I would put money on it being track debris.No big deal. If thats the worst thing that ever happen's to your car you will have had a charmed life
#44
Might be overkill but I would ask that they replace the whole joint and boot as a unit. If it was older and out of warranty and I was paying the boot only would be fine. Can’t wait to get my HTC.
#45
We will find out next week when we take it apart and examine it.
#46
yep I’m going to inspect the joint in the half shaft myself. If it’s not still fairly packed with grease, I’m going to have them replace it.
The following 2 users liked this post by Shaheen Javadizadeh:
AORoads (05-03-2020),
#47
You're clueless!! Have you owned any expensive cars in the past? I find that in a lot of cases, the more expensive the car, the more issues!! It's an all new car and it will have some growing pains! So what! That is what warranties are for! I am however concerned about fit & finish issues that may be or not be true cause those things really hurt the perceived quality of a car. Btw, if you guys want the ultimate reliable car go buy a $20K Camry!
The following 2 users liked this post by DaveFerrari458:
CorvetteBrent (05-04-2020),
CorvettoBrando (05-04-2020)
#48
carriccp (05-03-2020)
#49
The following 2 users liked this post by Kingtal0n:
#50
I did change my brake fluid for the track.
#52
#53
I have owned 25 brand new Corvettes starting with generation 4. I'm far from clueless when it comes to Corvettes quality. They are made from cheapest components they can find. I roll them over while still under warranty you NEVER want to own one of these cars out of warranty. They are low cost for a reason.
The following 5 users liked this post by Chevyrelic:
ArmchairArchitect (05-05-2020),
azvrod (05-04-2020),
carriccp (05-04-2020),
vettenevodrvr (05-05-2020)
#54
By all means if you don't mind pouring money into it keep it. Do you care to post a picture of your un repaired drivers seat?
#55
CF Senior Member
Get with it Man!
It's the world economy (or Order).
Quality control goes out the window when the
parts source is 10,000 miles away.
Until things change , all I can say is,,
Bring ,US manufactuer's, back to the state's.........
(Japan is starting a program to pull Japan manufact.
back to their home country).
#56
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
#57
you should be fine as long as you don't breathe on that rear diff too hard. Thank god for that strong onstar antenna on the roof to get you towed back home...
#58
OP any update on getting it repaired?
#59
Thats kind of funny you said they never skimp on mechanical components. My 06 had to have the harmonic ballancer replaced. Never before have i herd of such a need except for the c6 Corvette. I could go on and talk about the poor execution for the electronic brakes in the new corvette, or how about all the overheating issues on the c7 z06. Who makes a modern car that overheats when you use it for what it was designed to do?
Dont forget the cracking wheels in the c7 corvette Or all the problems with the automatic transmission in the c7 corvette.
Before you suggest someone go back to the needle point you might want to make accurate and true statement and stop talking out of your you know what....
Cracked wheels, overheating, auto problems... this has all been covered before. They happen, and when they do, people here complain. Did you even own a C7 or just like to talk about it? I've own two C7s (GS A8 and Z06 M7) and never had those problems... just lucky I guess?
I think the Vette does pretty well given the value proposition. Did you know that all cars, even fancier ones, have these problems? Certain Ferraris pre 2005 had headers made from cheap metal and so they all failed. Porsches including 911s pre-2006 had faulty bearings, a major problem. Did Vettes have a rep for bad interiors? Fer sure... you drive a C6. Get a newer Vette and you'll see the improvement.
The needle point comment was a little sexist but frankly you do seem an outlier...
#60
Pappy
