Reporting problems to GM
Is there a way to communicate directly with Chevy about issues with my 2020 corvette? Minor problems that don’t require going to dealer or issues the dealer does not have any info on. The Buick Enclave forum is regularly monitored by Buick and they will respond if someone lists a complaint.
call the concierge
I am curious, why do you not want to contact the dealer ? Your owners manual has a Customer Care number to call at GM, but do not expect them to have a lot of technical knowledge.
I remember a day when they used to be on here...not that it made a huge difference but they would respond in the c7 section
Moderator
Ask your questions/state your problems here. Others may know something.
Another example: If you select in preferences to have the mirror tilt down when in reverse and you fold the mirrors in, say pulling into your garage, and then back out in reverse out of the garage while the mirrosr are folded, then unfold the mirror they will not return back to the normal setting, but stay in the tilt down position. Discussed with dealer and he said that was probably the way they were designed. My Enclave has the same tilt preference but when I tested it the same way the mirrors come back to the normal position. Again not a biggie but something GM/Chevy should be made aware of. I am sure its an easy software fix.
yub (04-15-2020)
Received 5,239 Likes
Carrier pigeon, for all the good it'll do It's hardly GM's first go around at introducing a new Vette.
Received 8,880 Likes
I will give you an example: The infamous screw sticking out and potentially chipping the door when fully opened. My dealer looked at my car and agreed that 1/32" of clearance was not much but said fixing it would not be covered under warranty. This "problem" should be noted by production for future builds.
Sounds like you need to find a better dealer.
The following 4 users liked this post by Red Mist Rulz:
As someone wisely mentioned, Chevrolet decides what is under warranty...not the individual dealer. Chevrolet also does not pay nor authorize the dealer to undertake experimental solutions of their own making. The manufacturer will determine the course of action and issue a bulletin outlining the "fix" when and if that becomes the direction they choose to move.
Some people seem to be so consumed with their own interests they think these dealers, their employees, and the manufacturers themselves live in a bubble of ignorance and ineptitude. Factually, they know far more reality about current situations and policy/procedures than we will ever know. They make a living doing so and spend 24/7 involved. If they are collectively that stupid...how stupid are the people doing business with them?
The arrogance demonstrated dismissing this dealer as terrible, incompetent and saying to find a better one is staggering. There is certainly nothing in this thread yet to warrant that sort of omnipotent thought!
Personally, we’ve had to stop using a nearby dealer for service for one of our other vehicles because every time my wife would drop it off for an oil change she’d get harassed for $1,000 of “needed services” - none of which are called for by the manufacturer. At the last visit they marked “customer refused transmission flush, air filter change, brake change - may affect warranty” on the receipt. The air filters were literally 2 weeks old, the brakes have all new pads & the transmission fluid had been changed by me 2 weeks prior 20k mi before recommended in the service schedule.
So yes, there are plenty of incompetent service managers and personnel at dealerships who do not necessarily know more than the vehicle owner.
The following 2 users liked this post by JABCAT:
Bigredwing (04-17-2020),
LawrenceFromTorrance (04-15-2020)
I’m sorry but this blanket claim is factually untrue. There are many service managers, that many of us have dealt with, who are ignorant of actual policies regarding warranty items or even components/features on the vehicles they are supposed to service. Case in point from the OP & the issue with his mirrors not returning to original position “maybe they’re designed that way”. That tells me 1. The service manager, or whomever he spoke with did not know how they work & 2. Didn’t bother to find out to resolve the OP’s concern.
We have a car here with a mirror not working the way the buyer thinks it should. It works...just not the way expected. There have been 2700 new C8 Corvettes produced...less than one per Chevrolet dealer in the country. It is factual that there are 1000's of potential models and equipment variations available to dealers every model year going back decades...all cars going into Chevrolet dealers potentially daily for service. What kind of entitled ***** would call out the Service Personnel for not knowing why the engineers designed it that way. And, better yet, how long could you spend out of your year trying to find that needle in a haystack? If you don't like your dealer's people...get over it or find some you do. They'll struggle but probably survive!
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,106 Likes
The reality is that there are incompetent people in every line of work. The ignorant process would though be for us to assume because we disagree with the quality of one, they are all incompetent.
I’m considered an expert in my field of study, does that mean I know everything there is to know, no it doesn’t because my field, like many others, changes. However, being an expert in my field requires that I stay up-to-date on changes in my field, and if I don’t know the answer to a problem, to find the answer to the problem.
Based on the OPs experience as he recounted it here, the service personnel that he encountered either did not know the answer to the problem & provided an incorrect response that it was not covered and/or did not know the answer & refused to find the correct answer to either customer concern.
Based on that, the recommendation to find a better dealership service department was not unfounded.
Trust me on this GM has Moles all over the Forums including this one. Just post your issues here they are watching.
First you claim they know more than any of us, but then flip flop to how could they be expected to know everything about every car & there are incompetent people in every line of work - which is it.
Who exactly is the Service Manager to ask why the switch is the way it is. Some engineer designed it that way and thought it logical, evidently. The OP does not. Tracking down that engineer in a place the size of GM would be a fool's errand. Calling the dealership's Service Rep would though produce quite the laugh.
Me coming into your field, where you purport to be an expert and I have never worked in it, challenging your knowledge would be very stupid on my part. Where is the difference?
I really fail to understand why people like you, who seem to have a reading comprehension problem, consider it fun to challenge anything somebody says that might have a real answer. Yes, there are people in every field who are incompetent. They seldom last long. Yes, there are thousands of different vehicle combinations in a Chevy store multiplied by multiple model years. No, there are no Service Managers with all the answers...just like you claim not to know everything but consider yourself an expert. I dare say there are a number of other fields where all that is true.
Received 2,684 Likes
2018 C6 of Year Finalist
Send them a letter.
Hey Jallen4 - we agree most of the time but I must disagree with you here..most dealers, non-german, are clueless. Take my mother's G80. Took in for service for a wiper blade and they changed the oil at 3,000 miles. Add to that they used the wrong oil. When I ask why they changed the oil and used the one they did - the reply was we recommend change oil at 3000 miles and always use that oil. I told them I would rather go what the manual says. they changed the oil again.
when I went to purchase the G80 and the corvette both dealers taxed before the trade was taken into count. There they are either clueless or crooks. For mine they calculated as well the tax rate wrong. Again clueless or crooks. Also, the tires on my corvette where over inflated almost by 10 lbs or PSI 0- not sure what i correct but was 40 not 30.
The dealer in the above case should at least tell the customer we will contact GM and get some type of reply...at least seem like you care.
I have had an MB and Audi - both dealers where top notch.
