C8 Air Filter Removal/Swap
Received 11,622 Likes
Vet Interested (03-12-2020)
The following 3 users liked this post by Foosh:
Received 4,684 Likes
I’ve tried aftermarket air filters in the past, (specifically K&N) and I did not feel a “seat of the pants” improvement. For me, spending a couple hundred (maybe a few hundred) dollars, not feeling a difference, and having the possibility of warranty denials is simply not worth it to me. YMMV.
The following 2 users liked this post by BIG Dave:
ByByBMW (03-11-2020),
Walt White Coupe (03-11-2020)
The following 2 users liked this post by proeagles:
Tracy (03-12-2020),
Here are screenshots grabbed from the “MAKING THE FIRST EVER C8 CORVETTE CUSTOM EXHAUST!!! *COMPLETELY TORN APART!*” video by Street Speed 717. You can see the process for removing/swapping the air filter is pretty straightforward, and the engine will not need to be dropped, reinforcing the theory that GM designed the C8 for easy servicing. Hope this is helpful when it comes time for a new air filter!
Scheduled replacement at 45,000 miles, probably take most owners 22 years to get there. I'm good with a few bolts.
The following 4 users liked this post by Phil1098:
E-Ray, 3LZ, ZER, LIFT
Received 9,655 Likes
It's a bit technical to read and don't expect some of the "Vocal Minority" posters who don't accept you can have lower restriction filters as Tadge mentioned will. BUT some of the many "Silent Majority" visitors who the Thread who are interested might!
No you won't "feel" ~10 hp (which a poster using the aFe paper filter obtained in a dyno test versus the somewhat higher aFe showed of the ~15 hp dyno tests with the lower restriction oil cotton or with the LT4 it was sufficiently lower restriction than some needed a tune. BUT unless your "hard of hearing" you can't miss the loud "sucking sound" that is almost as loud as they exhaust. But then if you spent $1195 for NPP you got noise and 5 hp you also didn't feel!
Received 19,439 Likes
'20-'21-'22-'23-'24
Does not look difficult at all. Can’t see a need to take it to a dealer for that maintenance item.
JerryU (03-11-2020)
Doesn't look much more difficult than the C7! Done that a number of times. Once removing the OEM filter on my 2014 Z51; 2) installing the aFe low restriction filter system on my 2014; 3) then removing the aFe system when I sold the 2014; 4) installing the OEM system back on my 2014; 5) removing the OEM filer and system on my Grand Sport; 6) installing the removed aFe system on my Grand Sport (after cleaning the oiled cotton filter.)
Yep will change the C8 OEM filter and if I see I think there is benefit of installing an aftermarket filter, beit the high sucking sound I get now at WOT, or slightly more power- will install one!
JerryU (03-11-2020)
Depends on which filter you get. Flow with the same size as OEM in paper won't get much restriction reduction. Oiled cotton will usually provide lower restriction and you can clean more often that the ~30,000 miles you'd change an OEM filter, that by than will have more restriction. But you can just clean them about when you would change an OEM paper filter- it's your call! The downside is most low restriction oiled cotton filters (that are not larger and does not look like the C8 can handle a larger filter) will not filter as small a particle. Like most things in life, there are always compromises!
Banned Scam/Spammer
LOL! 10 Corvettes and I've never changed an air filter on any of them. It would take less time to reinstall the little screws than it would to trim, align, and place velcro tabs as you have suggested.
I lost the battle, so I took my engineering degree and left the battlefield. I was forced to admit that at 199 mph there probably was a ram effect, but I would not crater on the "laminar flow" bullshit.
RapidC84B (03-12-2020)
#34
I battled the "ram air myth" way back in 1999, getting in heated discussions with a well-known Forum vendor who had all sorts of wild claims back then with his line of C5 products.
#35
looks big with nice flow, probably change it at 100k miles
#36
Way back in bicycle days we had customer come for a new inner tube. She said, "my husbands a brain surgeon and cant change a lawn mower spark plug." She was dead serious, he really was a brain surgeon.
#37
Your comment is similar to one I use in my training material! I have a part time Internet business reducing shielding gas waste. Many welders feel the same and set excess flow that not only wastes gas but causes turbulence that pulls air into the shielding gas stream! I have a lock that can be put on the flowmeter control **** and other products that cut gas waste!
Graphic From My Training Material!
#38
It's a combo that requires a larger filter housing and they have a large smooth bend intake air intake tube. As you note, the filter is longer and wider. Also they show flow data at 1.5 inches of water pressure differential of: OEM = 224 CFM; their larger Oiled Cotton = 318 CFH and they also have a paper filter, the same size as the oiled cotton with ~275 CFM. So it's a combo of materials and size. Probably the issue with the GM introduced system that was paper and looked to be the same size filter as the OEM.
From my experience with oiled cotton it definitely has a luuder "sucking sound" at WOT. As far as the potential oil issue, done properly won't even fell oil. When you get the filter it's preoiled and does not feel at all oily.
I clean the filter with the recommend solution and then low pressure, low flow rate water from an outdoor faucet. Let it dry ovenoght. Then put a thin line of supplied oil only on the outer top of each ridge. It's colored and you will see how far it wicks down in about an hour. Then in areas that aren't colored, usually some at the bottom of the ridges, put a drop or two more oil. In another hour it's all colored BUT does not feel oily.
