Octane availability in California
After browsing through the just released C8 owners manual I noticed it says that 93 octane is required and use of 91 octane will void the warranty. Here in California 91 is the highest pump premium grade you can get without going to the track to get 100 octane. So what's up with that? Will us Californians have to add octane booster? Perhaps fill up at the track? Move out of Cali? Inquiring minds want to know.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,426 Likes
St. Jude Donor '08
Copy and paste from the owners manual.... Use premium unleaded gasoline meeting ASTM specification D4814 with a posted octane rating of 93 — (R+M)/2. If unavailable, unleaded gasoline with a posted octane rating of 91 may be used, but with reduced performance and fuel economy. If the octane is less than 91, the engine could be damaged and the repairs would not be covered by the vehicle warranty. If heavy knocking is heard when using gasoline rated at 93 octane, the engine needs service.
Do not use any fuel labeled E85 or FlexFuel. Do not use gasoline with ethanol levels greater than 15% by volume
He's right! MOVE.....
Seriously, we've run pump regular unleaded in many of our new Corvettes since the 1990's with no impact. Then again, we don't track em' any more so the performance loss was not an issue. I believe the State of California has a different way of measuring 'octane' and that's why it shows a lower number at the pump.
Honestly, what kind of performance hit would one take if using 91 octane vs 93? Can't even be measurable IMO.
Trash (03-04-2020)
The following 3 users liked this post by brAnd7onX:
Received 1,470 Likes
Cruise-In II Veteran
Have you ordered a C8?
Octane numbers are the same for all states. California doesn't calculate their own.
The following 3 users liked this post by wysokowski:
The following 2 users liked this post by jbsblownc5:
jamesampm (03-05-2020),
wysokowski (03-04-2020)
2017 C5 of the Year Finalist
St. Jude Donor '08
ratvet (03-06-2020),
False. 2 octane points can usually grant an extra 2-3* of timing when tuning (application specific of course) which can equate to 15-20 HP in NA combos. Boosted cars can make another 15-20 per degree of timing. So octane very much matters.
The following 5 users liked this post by Pb82 Ronin:
C6z06man (03-05-2020),
GTUnit (03-04-2020),
JerryU (03-05-2020),
vettenevodrvr (03-04-2020),
St. Jude Donor '08
I jumped on the dyno with straight 91 fuel in my 17 Z06, it made 481 RWHP, down at least 60 HP off what is should be. Sure, for those that don't need or use all the power their new corvette can make, they may not notice it. For me, I use every bit of the power and then some, so 60 RWHP loss is unacceptable!
In much of Utah, premium is only 90 octane.
Thinner air requires less octane (N/A), but you also lose a lot of power at altitude with a N/A engine. At Ely NV I figure I am down close to 20% from sea level.
I have lived in Utah all of my 88 years and have never seen 90 octane. It has always been 87 or 91 octane.
Corvette310 (03-05-2020)
