Using GM credit card points
Planning on a 2021 Z51, 2LT Coupe. Got myself a GM credit card. Anyone had any experience using points from the card to help with a Vette purchase?
Im guessing that getting a military discount as I did when I bought my 2015 may be tough to do on the C8. It’s up to dealers to honor the discount.
Used it on a 2013 and a 2019 without issue at Macmulkin, $3000 on the 2013 and $46xx on the 2019. (they allowed $5000 on 2019) The new cards have different rules then the one I have though. Had it since 2005 and mine is unlimited earnings but a cap on the amount you can use on each car, and points fall off after 7 years.
rramjet (10-31-2019)
Received 4,684 Likes
When will GM points be redeemable for c8?
Hi All
There is usually a lag on when the new car models are set up to acknowledge and points can be redeemable at the dealer. Anyone know that timing for the c8? You need to redeem when picking up your car and completing the transaction.
Be surprised if they allowed any in first year. But they should.
Called GM card
I called the GM card .They show 2020 Corvette is eligible, depending on your card type the limit is $1000 in points or unlimited if you have the “newer” card, which I have.
Unlimited here and C8 is approved to use on....
I have the old GM Card. Points expire after seven years. I’m hemorrhaging points every month. I just called and they said I could switch over to the new GM BuyPower Card with no expiration on points, however they’ll only transfer 500 points, and I’ll lose all my other points. So I’ll stick with the old card until the new 2020 Corvette comes in, I’ll redeem my remaining points, then swap over to GM BuyPower after that.
Received 2,900 Likes
St. Jude Donor '05-'06-'07-'08-'09-'10,'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
For you guys with the old card and wanting to switch, I'll gladly buy any additional points you have that you can't use after buying your c8.
I’m bummed!
I got my card couple years ago! Planning on new vette.
i built house and put all i could on the card!
i bought wife a new Equinox, made my best deal!
then whipped out the card. Dealer told me it would have a cap.
i told him not with this card!
7500$ off price!
i have about 3000$ more on it now to use on C8 with 2/3 tpw
7500$ off price!
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
