View Poll Results: would you perfer a mid eng or front eng corvette
keep front engine
46
24.60%
go to mid engine
37
19.79%
build both gives options to customers
87
46.52%
I don't care
17
9.09%
Voters: 187. You may not vote on this poll
Mid engine vs front engine
The vast majority of Corvette owners are not capable of driving it to it's limits in it's present configuration, so what's to gain from the mid-engine layout? That same group pf people want a car that is comfortable driving on a trip with room for more than two toothbrushes.
Received 2,379 Likes
You can't just "go AWD." There are space and engineering requirements.
when Zora first started talking about a midengine corvette, the terms fmr and rmr had not yet been used. there were just front engine, midengine and rear engine cars. however, when mazda introduced the rx7, its engine was so far aft that they wanted to be able to call it a midengine, so they coined the designations front mid rear(fmr) and rear mid rear(rmr).
it seems that in order to avoid this constant discussion from now on, we'll have to use the more narrowly defined terms. the c2 to c7 are fmr cars and the new model is an rmr car.
nevertheless, the fmr c7 does not turn as readily, quickly and easily as the rmr zora spy photo version that we have seen photos of because it has about 270 pounds more weight on the front wheels than does the fmr c7s.
(assuming 3350 total weight for each, 50/50 weight distribution for the fmr c7 and 42/58 for the rmr zora)
every serious performance car manufacturer except mercedes, gm and jaguar have rmr versions available, and considering that fiat owns chrysler and ferrari, it is well represented in that department. mercedes plans this different approach non rmr awd hybrid
http://auto.ndtv.com/news/mercedes-a...r-2017-1454577
gm has the zora planned for introduction in 2019. that will leave just mercedes and jaguar without an rmr model. obviously, the handwriting is on the wall. most performance car manufacturers will build an rmr model because it is good for business and, all other factors being considered, has the edge in handling and performance on roads and race tracks that aren't short, straight and drag race only.
E-Ray, 3LZ, ZER, LIFT
Received 9,647 Likes
As far as the mid-engine goes, I wonder about weight distribution issues. Seems GM prides itself on maintaining an approximate approximate 50/50 front/rear weight distribution with its modern designs. What happens to weight distribution when the front of the car is just an empty storage space?
Suspect that light weight turbo V6 I bet they use to help their corporate mpg average will keep the overall weight low. While speculating on the engine, one reason for mid engine is the overhead cams it will no doubt have are too high an engine profile for the current Vette low hood!
Since Tadge and Lutz are both on record stating going mid engine only adds $5k to the C6 Corvette, I have to shake my head at anyone voting for them retaining a Front Engine car, even as an option.
Polls like these are why I'm embarrassed to be a lifetime Corvette owner sometimes.
I wish the DMV required a IQ test to register a Corvette.
My guess is they will aim for 45% front and 55% rear. With weight in the center and low polar moment of inertia (neither end acting like a pendulum, like my modified Corvair) that is a good ratio.
I want them to move to mid-engine. GM is already offering amazing performance that competes with most exotics. Why not match them in the wild design category as well? The ME layout allows GM to start with fresh designs.
the world economy is on very shaky grounds at the moment, so cheaper might very well be better should a serious downturn happen between now and 2019.
I would like to see (and own) a mid-engine design Corvette, but most likely the price will be close to $150K, so it may price a lot of Corvette owners out of the market.
Right now, I would be more likely to buy a mid-engine than a Z06, even at the higher cost.
I read somewhere the C7 design will probably continue through 2021, and the C8 (probably mid-engine) will be introduced in 2018. If that's true both production lines will be running for 4 years. GM may do this to see where the sales numbers go on each design.
If so, the Economy of Scale will keep the prices in check.
#33
What I wss told the car you see testing will be the special zora car. It will arrive in late 2018 as a 2019. The C8 "stingray" or "Manta Ray" will arrive in 2021 based off of a less expensive mid engine version of the Zora car with a V6 and with lesser specs with its own modified exclusive body work. The folks at Cadillac will also get a version of one or the other.
I was told over a year ago that all major improvements for Corvette (mid engine, DCT, AWD) would come from Cadillac.
So, what we are seeing is either a Cadillac, or a Corvette that shares Cadillac components.
The pushrod V8 engine with a stick is the only reason I buy GM.
I do not want, nor will I buy, a V6 Corvette.
If federal government regulation forces Corvette to go V6, it had better make ZO6 power in a mid engine layout with both DCT and AWD for me to consider it. If not, the 911 Turbo is the choice for a 6cylinder performance car.
Please explain your "pure form" comment as I bite my tongue.
#34
The pushrod V8 engine is the only reason I buy GM.
#35
The above makes sense.
#37
Corvette gets a new frame every other generation. Are you trying to say a 911 TT is larger or higher than a z06? Somehow they do it just fine.
#38
Bingo! You're right! And as far as a "mid-engined" Corvette make that too for the wealthy folks. As for me the 50-50 bias now is about as good as anyone can get on a front engine car. Why screw it up?
#39
yeah they hang the motor behind the rear bumper of a VW Beetle, that frees up a lot of space. The 911 is a rear engine car, not even a mid-rear engine. As a mid-front rear drive vehicle, the Corvette is not conducive to AWD. And quite frankly the spy shots of the mid-rear car look pretty terrible, hopefully it doesn't have anything close to the same shape. There are some beautiful cars out today and leave it to GM to late release something that looks like it was dreamed up in 1989.
#40
What would I rather? I mean, mid engine is objectively better, all else being equal (this poll doesn't have other considerations)
GM isn't just abandoning it's mass produced 60k great performer market segment it basically outright owns. It's not just going to make all Corvettes $150k.
I'm guessing a lot of you aren't involved in running a business.
pdiddy972 (02-10-2017)
