What transmission will the e-ray use?
I suspect it’ll use the same as the Stingray, but who knows. I’m making the assumption that they spec’d the Stingray Transmission with the E-Ray in mind.
Transmissions are rated by torque not HP regardless I would think the Stin
gray or Z06 trans would have to be upgraded
The following 14 users liked this post by Red Mist Rulz:
BIG Dave (01-16-2023),
BobG (01-16-2023),
Buddhaman (01-16-2023),
C82LT (01-18-2023),
foundvettelifeisgood (01-16-2023),
and 9 others liked this post.
Curious if it will have a pancake electric motor between the V8 and the DCT. Most of the hybrids have this, as it produces torque at the rear, can spin or slow the crankshaft, replaces the starter motor, and would allow AWD full electric operation. Is "Stealth Mode" going to be FWD only....?
Electric motor at the rear of a Zora with a LT7 TT would help a lot with boost lag as well.
The rear wheels only have the same LT2+DCT from the normal Vette
Any power taken from the ICE to drive the motor or charge the battery is taken out before the DCT.
So the transmission does not need to change.
If anything it is lower stress than in the base C8.
