E-Rays at the Nurburgring
I wouldn’t get too caught up in 1/4 mile and 0-60 times between the Eray & Z. AWD is going to get you out of the hole faster. Combine that with the increased torque out of the 6.2 and the electric motors in the front, I wouldn’t be surprised if it runs the 1/4 faster than the Z. The Z isn’t designed to be a quarter mile ground pounder. It’s a true elite track car.
The following 4 users liked this post by BrakeFade:
The following 5 users liked this post by GOLD72:
Av8ing (08-10-2022),
BrakeFade (07-24-2022),
JTBogus (08-08-2022),
Schuee (08-09-2022),
SoonerSpeedFreak (07-23-2022)
I'll take a 0 to 60 in 2.5 sec and quarter mile around 10 seconds over the flat plane crank high pitch sound. Thats just me
The following 5 users liked this post by kevinprimetime:
BrakeFade (07-25-2022),
lostsoul (07-23-2022),
SoonerSpeedFreak (08-20-2022)
Yep same here. But I'm probably going to buy a C8Z and an ERay just for the people that bitch on this forum about the ERay. That way when the LT6 bespoke engine breaks...thus becoming the "bebroke", I can have my LT2/Hybrid ERay to drive around why the C8Z is at the dealership getting repairs. I'm not joking.
The following 2 users liked this post by Shinobi'sZ:
kevinprimetime (07-24-2022),
LukeyW (07-23-2022)
Reality is that AWD 0-60 isn't comparable to RWD 0-60.
The following 2 users liked this post by lanza:
100% confirmed. There is a yellow sticker on the window that tells safety staff it has electric motors (high voltage).
The following 3 users liked this post by BrakeFade:
Performance should be compared or close to the Acura NSX. That car runs 10.70's around 130 1/4 mile. And the unforseen horsepower should match. Anything under 100 hp is nearly a waste except for the nice looking widebody.
The C8 Z06 is severely torque limited at only 470 ft lbs !
#33
Received 4,383 Likes
The physics are the electric motors are that torque accelerates cars from a stop , the HP gives them the speed . The high torque electric motors although only 50 hp each = 100 hp combined additional with the added benefit of doubling your torque out put to 4 wheels instead of 2 .
Electric cars still have to live in the physical world and live within the laws of physics.
Ramv (08-17-2022)
#34
Most electric motors only have a final drive gear reduction. Gas motors use a multi-speed transmission and a final drive. Torque at the wheels per unit of time is what matters. Amazingly that is HP. You can have a million pound feet of torque at the wheels, but if it only has the HP to go from 0 RPM to 1 RPM in 1 sec, you will not have a fast accelerating car. Electric motor torque is limited by current. Power in an electric motor is measured in watts. A watt is 1 amp x 1 volt. a 100 HP electric motor is about 74600 watts. to produce 100 hp at 1 RPM and running on a 400v system would need about 186.5 Amps. The wires in a motor are of a certain size and can only flow so much current before they have heat and other problems. If the motor won't support 186.5 amps it won't support 100 HP at 1 RPM. THe controller is the devices they determines the voltage and current that goes to the motor, it is designed to only allow a maximum current and voltage, and wattage to flow. People say that electric motors produce maximum torque at 0 RPM. Theoretically yes, practically no. Let's go back to the example above. If the 74600 watt motor is at 0 RPM, it will require infinite current to produce 100 HP. A battery will not supply infinite current, the controller won't allow it, and the wires won't support it. This is easily seen in a Tesla dyno run.
#35
#36
I am not sure of your point? I suspect your math is correct, but getting a 100 hp out of an electric motor in the physical world should be pretty easy. The Tesla S Plaid with 3 motors has over 1000 hp. The new Cadillac Lyriq AWD is suppose to have 500 hp - 160 hp in the front motor. The 2 motors in my Tesla X have over 250 hp each. GM is rumored to have an Ultium 83 hp electric motor. Seems to me 2 of those up front in the ERay should be the minimum.
Also the motors alone don’t determine the HP electric cars make. The batteries and controller does too. Why do you think Teslas make less HP at half capacity. Whereas a gas car will make the same power with half a tank of fuel.
Oh and motor torque alone does not determine acceleration. Otherwise diesel trucks would out accelerate Corvettes, and they don’t.
It is very clear many posters don’t understand basic physics, and believe many myths.
#37
Look up Vector Control, or Field Oriented control. Also check out the Plaid dyno from Tesla themselves, it shows the linear power region and the constant torque region.
https://www.tesla.com/blog/evolution...rol-waves-bits
https://en.wikipedia.org/wiki/Vector_control_(motor)
The problem with many of the online dyno tests, is the dyno itself. Inertial or eddy-current dynos are not designed to be able to register steady state torque at 0 rpm, and they typically struggle to accurately read the very steep torque ramp. Also, it takes a small amount of time for current to fully build up in the motor inductance. Many dyno tests start at something other than zero rpm and unfortunately catch these ramp effects. A little more than three decades ago, for part of one of my grad degrees I needed to build an electric motor dyno that measured torque at a locked zero rpm, along with fast transients everywhere else in the rpm range, and it worked by directly measuring motor current.
msm859 (08-18-2022)
#38
The point is electric car fan”s ideas about how electrics motors work in the real world are wrong. Tesla don’t make full torque at zero RPM or even 1 RPM. It is clearly shown in a Tesla dyno. Because they are generally direct drive (Tesla is) with no clutch they don’t function in the same way as a gas car.
#39
Looking good. The car seems very planted no stepping out from the back side exiting a corner. Maybe they are not really pushing it that hard in the vids? Up to the engineers to dail in the awd/vectoring.
If the price is reasonable, and the track performance is close to the Z06, all those Stingray buyers will put there $ on the Hybrid instead imo. The line will be as long or even longer for this GS/ERay/Hybrid.
#40
'Course they can, or pretty dang close, not counting launch control limiting or other nonidealities. I'm a big mechanical ICE fan but in my spare time, I make my living over on the (very very low voltage) Dark Side .
Your point on the dyno problem is fair. I don't know what type of dynos they are running, The point of power being limited by state of charge of the batteries is real. The torque and power being limited by the controller is real.
My other point was torque alone does not determine acceleration. Without the time component acceleration doesn't occur and the time component gives you horsepower, so horsepower, with the proper gearing is what gives you acceleration. Otherwise F1 cars would not accelerate well. Their torque numbers over the years have not been impressive.
I look forward to seeing the new Challenger EVs for Stellantis. It appears they are planning to use multi speed transmissions. It should be interesting.
RedLS6 (08-18-2022)
