ideal electric only range? i would love 20, but have a feeling we will only get 10
I would love 20+ electric mile range. But i have a feeling we will get 6-10 on the first go around. thoughts?
SOOO excited about the eray.
Here is my current 23
So it "should" be a PHEV, which means it "should" have an EV range of over 15 miles. And that is the only way it will be able to put big numbers on the board i.e 50+ MPGe. I would "hope" they are in fact shooting for the 20 mile ev range. The only way you would see under 15 mile ev range is if it is Not a PHEV and then it would be a wasted exercise in engineering.
lostsoul (06-28-2022)
I'm not sure the term "range" will really fit in this case unless it is a plug-in hybrid, which I doubt. The car will determine the state of charge of the battery. So the battery is not likely to be at full charge all the time.
Received 1,257 Likes
2016 C5 of Year Finalist
If a Subaru can do17 miles on a battery, a Corvette
that costs 2 or3 times more should get over 20.
extraneous factoid
There are 6000 charging "stations" in the US and 150,000 gasoline stations. Even the intended "expansion" by the govt leaves large areas of the country unserviced.
So range from where to where?
Only1cannoli (08-01-2022)
It is a balancing act of size/weight of battery and range. I agree I would love a 20-25 mile range. The advantages is that a battery large enough to give that range should not weigh too much and would allow more powerful electric motors that would make it quicker - even with the extra weight. I would want to know what size electric motor(s) do you need to get a 0-60 in 2.5 or less? What size battery do you need to support said motor(s)? What size battery would fit in the tunnel? And what size battery do you need to get a 20 mile EV range. Work within those parameters. Costs should not be part of the equation because at @$125/ kWh whether it is 8 or 15 kWh the price difference is insignificant.
How is number of charging stations relevant for a hybrid? Are you referring to if the E-Ray is plug in? If it is, which I doubt, couldn't you just plug it in at home? It's not the all electric that is being discussed in this thread, from understanding.
Tripjammer (07-17-2022)
Actually the bigger problem with "counting" charging stations is most people who do not have an EV forget to count the "charging" stations most EV owners have in their garage. Most EV owners can simply charge up in the comfort of their home. No ICE cars have that luxury. As to the "ERay" or whatever GM calls their first electrified Corvette, that should be a hybrid and Hopefully a PHEV that can be easily charged with any outlet.
The following 2 users liked this post by msm859:
NotScared (08-06-2022),
Patiently waiting for anything 'official' (release date, power, 0-60 time, EV range, etc.) from GM. I hope the E-Ray does at least 25 (the more the better) miles on the battery before the engine kicks in. Otherwise, why bother?
msm859 (06-30-2022)
Back on topic. Most will definitely charged it over night at home like my co-worker does in his Volt however it will not last his trip home.
That is a good point. A balance between weight, range and performance 0-60. Would GM sacrifice a little performance for better MPGe? I might suspect so? That may be an more attractive pkg say 0-60 same as the Z06 with high MPGe. That maybe the marketing point for the Hybrid C8?
What is the purpose of the e only range in the C8 hybrid that people envision?
That was the reason for my observation as to the limited availability of high speed charging stations. By the by, not all Corvette owners live in separate units that enable parking and charging. Although some apartment units are considering parking lot charging capabilities where a parking lot is available. And some towns are considering free charging as well as free parking to draw the consumer back down town.
For example, if you wanted to access an area where e only vehicles are permitted as a metropolitan area, you could drive to the area using the hybrid "normal" mode and then within the e only area using the e mode. Is that what is being imagined? Definitely would require a plug in capability?
My mind is on a performance hybrid so I envision filling in the lower part of the torque curve of the e/IC propulsion unit for better acceleration from standstill or lower speeds. So I'm having difficulty understanding the intended use of the e only range.
Received 4,383 Likes
The reason, that MOST EV owners may have a charger, is because they have to, otherwise they would be out of luck keeping their car charged. Near where I do more that a few people have fuel tanks where they live, because they have farm equipment. So you comment that no ICE owners have home fueling is false.
Before you say that I am anti-EV I will point out again that had 240V outlet put in my garage just for EV charging, for when one meets my needs. I am anti-EV hype that they are the salvation of the world, and meet 95% of people’s needs right now.
The following 3 users liked this post by Racer X:
While it may be true that many people that can afford 60-130k plus EVs have a free standing home, and may be able to have a home charger. You live in California with a much higher density of public chargers. Over 100,000,000 people don’t live in free standing homes in the US. We have discussed you myopic view of the world that comes from a very privileged perspective.
As to your concern for anti-EV hype, I admitted I believe in climate change and have been working to reduce my carbon footprint, however, put ALL of that aside and for a daily driver an EV wins hands down. The smooth linear abundant power is far better than a typical ICE vehicle. The minimal maintenance, features etc. Forget all about climate change. Once EV's reach price parity the overwhelming majority of people will buy an EV for the better ownership experience. I agree that today they do not meet everyone's needs, but they are getting closer every day.
Nice car. Tide you over until your Hybrid C8 arrived. I'd hope you are near front of the of the list but then again you have the Stingray in the meantime.
Right now we are talking about a hybrid that will have a small battery. A regular 110 outlet should add @ 3 miles per hour. If it came with a 20 mile range that would be 7 hours. 2/3rds of Americas own their own home. I would not call that a privileged perspective. I do live in a progressive state that is working on making sure the infrastructure is available for all. New homes in CA have to have solar, They have to be wired for an EV in the garage. The latest new apartment I saw in my town advertised solar and charging for EV's. As to farms and fuel tanks, we have those too. They generally have red dyed diesel - for off road use only. I would suggest not only is that rare if you want talk numbers, but it should also not help with the question of gas stations for on road use.
I see an awful lot of people driving in my area in old pickups with work gear to build houses. They are not driving from close by. I would be willing to bet that an electric that would meet their needs, that they could NOT afford it, thus not meeting their needs.
St. Jude Donor '19
The following 2 users liked this post by C7Me:
BrakeFade (07-29-2022),
COSMObudman (07-02-2022)
Well if you want high performance than the byproduct will be more EV range. To have high performance you need higher hp electric motors and they will need more volts which means larger battery which will mean more EV range. So I am with you - give me 200+ hp electric motor(s) with a big enough battery to give them the sustained volts they need to be a real performer.
