ZR1 brake rotors
ZR1 brake rotors
Hi gang, for those of you that have had to replace your front brake pads on your ZR1 did you have to/need to replace the rotors as well? My past experience has been that I would get 2 sets of pads changed for every time you had to change the rotor. I don't track my ZR1, but it's got approx. 62K miles on it now. Also does anyone happen to know who/where I can find the best price and availability on the rotors? L:ooks like the best I can find so far is Rockauto at approx $ 3800.00
Pro Mechanic
Pro Mechanic
Don't replace carbon brake discs unless they're chipped or cracked or weigh less than the minimum weight for the disc in question. With carbon rotors thickness is irrelevant.
The following 2 users liked this post by Hib Halverson:
magredrod (03-03-2024),
Thomasmoto (02-26-2024)
As Hib said about the rotors. I'm surprised that a non-tracked car went through 2 sets of pads in 62K miles.
I am surprised too. I see an awful lot of vehicles come through my shop with CC brakes that I am certain never see a track. Almost all of them have hardly any wear on the pads.
Zr1
It’ll be highly unlikely the rotors are done in for just a street driven car. You have to really be going hard (like at a track) where you might actually see some red glow from the rotors to get them to a point where the rotors lose density.
There is an individual weight printed on every CC hat/rotor assembly. Measuring the weight is a bit of a PITA. Taking the brakes apart, thoroughly cleaning the rotor assembly (including all the little holes), then baking it in an oven to evaporate any remaining solvent….its quite an ordeal.
To be honest, I have never paid attention if these numbers and marks are there on Corvette rotors, but there is a much better way to measure density.
This can be done on the car, maybe even with the wheel still on. This Proceq-Carboteq wear indicator lines up to a few pre marked lines on the hat and it measures the density. The spec is printed right next to the mark and you know in seconds if you’re still good.
Now I’m not saying go out and buy this $6k+ on one of these. Just go to a shop that has one and pay them a little to have them spend 10 minutes to measure your car in the parking lot. Guaranteed that any Porsche dealer has one. Also Audi and Lamborghini will have them as it is a VAG required tool for dealers.
The following 2 users liked this post by TheRobSJ:
SouthernSon (03-02-2024),
Thomasmoto (02-27-2024)
Zr1
So it turns out the rotors are fine. The pads are only about half gone. I was getting squeal and the brakes worn message and figured it was time to do the brakes, 66 K miles so It must just be dust that's causing the noise and the sensors look a little bad so I'm going to replace them as well, on order. I was also informed that there was a program flash to the ABS system about the warning. The pads still look pretty good, they only had a few little cracks in them, but I'm still going to change them as soon as my new sensors come in.
How is weight a factor if thickness isn’t?
i would think the weight is directly related to how thick the rotors are. And it falling below weight is tires to wear from the pads.
what am I missing?
thanks
The best measurement to see how much carbon you've burned is by weighing them.
Too-Fast (03-03-2024)
