What to do about Weapon X MotorSports
The following 2 users liked this post by TheRobSJ:
ernhart333 (08-09-2022),
Repo Pilot (08-09-2022)
It also looks like with the smaller end-caps you could lower the wing snother 3/4 to 1/2 an inch and still have acceptable clearance between it and the top of the fender.
That looks great Rob. Can you see anything but wing in the rear view mirror? That's my only gripe about the WeaponX setup. It also looks like your end pieces are different from what my Factory wing was delivered with. Whose end-piece is that?
And your ZR1 looks amazing. Surely one of the sweetest ZR1's I've ever seen!!!
My end plates are different because it’s all the stock non-ZTK setup. ZTK has much larger end plates and slightly more actual wing surface area compared to the low wing.
Kinda what I was thinking and thanks for verifying that. Actually for the straight line stuff I cant think of a good reason not to just take the wing off and maybe avoid life north of 200 on days with a gusting crosswind. There was no wind at all when I busted 200 and the steering wheel was dead center the whole way once I got through the launch and into fourth gear.. I think I'd do more to reduce drag by removing the vertical cannards from the front splitter.then messing with a lower wing mount.other than the WeaponX mount I'm using now
Ive actually got them drawn up, and a much better design.
My design moves the wing "Forward" about 1" closer to the trunk lid.
I have the WX lower brackets on my ZR1 and feel the wing needs to come forward some, so I redesigned them but we are so busy working 7 days a week I just never got time to run a few sets. I can send you the print in exchange for a set you can run for me?
The following 2 users liked this post by DSteck:
ernhart333 (08-12-2022),
Repo Pilot (08-11-2022)
If we could get a half dozen or so takers, I would perhaps spend a weekend in the shop and make some up.
(PLEASE NOTE: I am not saying this to make money or generate work for myself....... My only intention is to help out and NOT get myself in trouble here with the forum admin)
I admittedly know zero about production CNC work, but I assume this would need a 5-axis? Is your print something I could upload to a service such as RapidDirect (no affiliation, just a link that popped up when I googled) and they'd be able to make me a set? If so, any chance you could send me the files? I'm kind of desperate for some.
No the brackets could be machined on a standard 3 axis machine (would require a couple operations) and my Cad prints would need to be generated into a Cam file for machining or for a 3D printer. So without the Cam software, my prints are useless. And for providing the Cad prints I would ask to receive a set in return for my time measuring and designing the brackets.
Lets see if there are any others needing and/or if someone here on the forum is willing to make up a few sets.
I ended up getting my Weapon X lower brackets from GS Creations. I paid more for them but at least I got them whereas Weapon X had no idea what was going on with their manufacturer or what the status even was.
ernhart333 (04-13-2024)
#33
If there is somebody making aftermarket brackets like these, I would personally like to make a suggestion. If you can make the brackets where the wings sits a little little bit higher than it currently does with the Weapon X lower brackets. So not as high as the standard ZR1 wing but a little bit higher than the lowered brackets. Or even better have it so that you can adjust the height so you could actually set the wing as high as you want to..
#34
They are sitting in the closet wrapped up. If anyone is interested, $300 shipped. Believe they are $359.99+tax at weapon x.
ernhart333 (04-15-2024)
#35
#36
**** sold ****
