2019 ZR1 vs ZO6 comparison
#41
disclaimer: i don't have a Zr1. I have a Z06/z07 with mag ride update. I've never driven a Zr1. But I do track a lot. I tend to be harsh on the zr1 due to the cost. I'd love to have one. I'll try and be objective.
Here are some facts:
ZR1 brakes are the same as z07 (perhaps different pads?)
#42
I’ve already said my peace in this thread...But I’ll add this...There is no question the ZR1 is better. Period.
Where the extra money likely can be justified...other than the obvious HP, cooling and overall performance is exclusivity and knowing you own the LAST front engine, manual Vette EVER made...853 of them. Not seeing those at every corner like a base C7 or Porsche...
#43
#44
#45
I’d feel more comfortable rolling through the “hood” or past a cop in my all dark colored ZR1 then I would with a bright yellow or red base Stingray 1LT with chrome wheels, race mufflers, and the stereo blasting with the windows open. In the end, to your typical bystander, a Corvette is a Corvette. They don’t know the difference (and price tags) between Z51, Z06, and ZR1.
#46
https://www.automoblog.net/2018/01/0...brembo-brakes/
The following 2 users liked this post by BillY2KFRC:
NofakeJake (05-15-2020),
Thomasmoto (05-15-2020)
#47
Zr1
Here are some details on the ZR1 brakes; essentially a special heat treatment to the rotors and different pad compound front and rear.
#48
I had a 16 Z06, it wasn't a Z07 with the stiffer suspension and better brakes but I did update the MRC with GM's update and that definitely helped it to ride better, etc. Never really tracked the car in any HPDE events but plenty of shenanigans ensued elsewhere. I've driven plenty of Z07 versions as well though with and without the MRC update, just never beat on them like that but their ride was even stiffer. That being said the ZR1 is just better in every single metric I can come up with outside of initial cost and somehow it just feels more refined all over, the ride is a bit stiffer as to be expected but it feels "smoother" if that makes any sense and everything about the car just feels better.
As far as the cost of a ZR1 vs a Z06 that's ALWAYS a personal choice and everybody is going to have their own opinion of it. The fact that there were less than 2900 produced and only for a single year means it's going to be more exclusive and more expensive no matter what and then throw in the engine/blower changes, suspension/brakes, etc and to me it was well worth it. Any ridiculousness being mentioned about feeling safe while driving it through the hood or whatever other crap somebody comes up with is pretty funny though, I don't think anybody who owns a ZR1 is even remotely concerned about that.
The following 4 users liked this post by NicD:
#49
I had a 2016 Z07. Manual. *LOVED* it. Tracked it over 40 times (I need to check my log for the exact number of days). Bought a used ZR1. Also manual. I've had it on track about 9 times. Turns out I had an issue with the high pressure fuel pump, and it was robbing me of horsepower. So I was kind of underwhelmed with the ZR1, thinking it was not that much different than a Z06/07, on the track. It was louder, the brakes are *amazing*, but I wasn't that much faster. I've been on track once since I got the new high pressure fuel pump installed, and I was on worn SC2 tires (they corded later in the day), and I still ran faster times than I had in my Z06 (same track).
After getting the new fuel pump, it was like a new car from 80 to 150 mph (as fast as I can get it before the brake zone into turn 1). Night and day. With the faulty fuel pump it felt basically like a Z06. With the new fuel pump, the thing is a beast.
Is it worth the extra money? That is for everyone to figure out according to their financial situation. Speed costs. And it doesn't increase linearly with speed---cost goes up exponentially with speed.
But I have to go back to the brakes. A few days ago, I out-braked a Porsche GT3 Cup racing car that weighs a lot less. I routinely out-brake Ferrari's, McClaren's, Porsches, Lambos. And I've noticed the rear pads last about 2X longer than the Z06 pads. The front pads, alas, only about 1.2x longer.
PS: for me, the "burble" of the ZR is worth $10k easy. hahahahahaha
#51
My Z06 was an A8 and my ZR1 is an M7 and I am feeling like you. Doesn’t seem all that much faster at times (seat of my pants). Maybe it’s the gearing or it puts the power down so much smoother, but I’d like to be sure.
Oh, and that “burble”.... the Corsa double helix X-pipe will make it twice as long and twice as loud and worth an extra $10K
#52
Thanks for the Corsa double helix tip! I'll check it out!!
As for the fuel pump issue, it only showed up on track (never on the street, perhaps because I rarely drive it except to/from the track---but my suspicion is because you have to be on it hard for it to manifest itself). It would *intermittently* "stop pulling" at about 5k RPM. When I say intermittently, it didn't happen every track day. When it did happen on a track day, it didn't happen every lap. It would happen in 2nd and in 3rd gears, and up-shifting acted normal. When I say "stop pulling" I mean it felt like the torque just plateaued---kind of like at rev limit but without any of the engine stutter you get at rev limit.
Now that I know what a full-powered ZR1 feels like, I would be able to spot it quicker. I'm a little embarrassed to say in a forum of experienced Corvette drivers (on track and off track) that for a long time I just talked myself into the ZR1-isn't-that-much-more-than-a-Z06 camp. It was a reasonable explanation for why my speeds on the straights weren't any better than the Z06 (I blamed the big wing). But I took it into the dealer because of this intermittent won't-keep-pulling-past-5k-rpm issue. They contacted Detroit. Nobody else has reported this problem for a ZR1. Replacing the high pressure fuel pump did the trick.
Hope this helps and isn't too confusing.
#53
#54
I share the track with one guy that has a couple of Lambo's, a couple of Ferraris, and a couple of McLaren's, including a McLaren Senna.
That Senna is SOOOOOOOO quick. Beauty and function.
The one time I was on the track with him and the Senna, I still had the fuel pump issue. Would like to do it again, with fresh tires and now at full power. Of course the Senna is faster, but man is it fun to be on the track with!!!!
#55
Anyone have experience running a highly modded Z06 compared to the ZR1? Just curious how an 800+ HP Z06 would compare.
#56
Best $599 I ever spent .... if you are into sound and want to pick up a few horses! My best friend heard mine and ordered one from his cell phone on the spot from the parking lot Hahaha
https://weaponxmotorsports.com/colle...1-lt4?variant=37647884305
#57
NofakeJake (05-16-2020)
#58
The pads are a big step up, definitely an improved compound. A friend uses them on his 2017 Z07. He won't give up the CCBs, likes them on the track. Since putting the ZR1 pads on the rear rotors look like they have stopped pock-marking. Fronts ceramic rotors are still going to need replacing, but the ZR1 pads are helping lengthen their life.
I'm surprised GM didn't put this compound pad on all the '19s.
BillY2KFRC (05-17-2020)
#59
I good place to see a heads up on the street is youtuber Corvettes 918. He has some footage running them together.
For me tho, I have a 2017 Z06 and a 2019 ZR1 and despite the numbers being not so different on the torque side, it has a completely different feel in the overall power band and feels way smoother and faster as a result. There is no initial bog/tip in with it compared to the Z06 from a stop acceleration.
DebRedZR1 (05-20-2020)
#60
Can I buy the zr1 rotors and pads and put them on my z06 w/z07 package? Are the calipers the same? If they last longer that would be huge. Especially because the z06 is lighter and has less hp.
