C7 Z06 X PIPE... Which is best?
I'm looking for input on which X-PIPE is the best for my 2019 Z06 M7. I don't want to add headers or replace the rear mufflers. I've seen Corsa, Borla, and AWE.. and I'm sure there's more. I would like to hear from those that have actually done the conversion. Thank you.
I did Corsa, but it was pre-anti cat deletion days so it will be a little different than current models.
sounds cool. Not much difference at idle and low throttle but WOT is a good bit cooler
I bought a cornerstone xpipe from ebay a year ago and like it,its connected to stock headers. it was around $500, made exhaust louder and increased some power.
Received 1,083 Likes
2019 C6 of Year Finalist (performance mods)
AWE on my Z06. Louder on start up and under heavy acceleration. Cruising about the same as it was before the cat delete AWE was added. Sounds great when you get on it and overall has a cleaner crisper sound at least to my ears. The AWE is a 3" pipe size. Fit up was perfect no install issues.
havent had any other but happy wit the awe i got new 2+ years ago before they stopped making those.
either way any used or new xpipe that removes the cats is going to be better than the stock xpipe with cats.
so you cant go wrong with the choices you have, I just wouldnt spend more than $650 on one.
I know this isn't the right place in the forum, but I just took off a Borla 60457 from my 2018 Z06. I replaced it with long tube headers and tuned. The X-pipe has maybe 1000 miles, the whole car only has 2400. Send me a message or call (740-541-6199) if interested, as I'm not going to use it. I'd take $350 plus the shipping. I can email a pic of it.
Brandon Unklesbay
All-In Performance, LLC
Brandon Unklesbay
Brandon Unklesbay
Brandon Unklesbay
