Convertible top wont open
New to the C7 forum, I've got an 08 Z06 which I'm about to put up for sale. Just picked up a 17 convertible ZO7 package every option available with 4300 on the clock. Top will not go down via the fob or the button on the dash. No codes open on the dash? Good to join you folks!
Thanks, John
Thanks, John
There is a 15 amp fuse in the fuse box in the trunk. Maybe check that. # 34 on the diagram. Also, if it was only the FOB you would need a new FOB battery.
https://fuse-box.info/chevrolet/chev...uses-and-relay
Thanks, John
Thanks, John
If it does not lower using the button on the dash then it has to be a fuse or some other electrical malfunction that may require a visit to your dealer for service.
Dont forget to make sure the partition in the trunk is properly fastened. Occassionally, mine will look good, but one of the two 'button things' need to be pressed in a little harder.
The following 3 users liked this post by jc123:
