Just had dealer flush coolant on supercharger and cooling system, running hot now
Had local dealer that works on a ton of Vettes flush both systems while doing an oil change. Now I’m running 230-240. In Arizona and it’s hotter today than past weeks @ 110, but this seems excessive. We were running it a little faster but it’s still hotter than normal by 10-15 degrees. They miss something? I specifically told them to make sure to properly bleed both.
Leaving on a long trip, any advice would be greatly appreciated!
If they replaced your thermstat with a new one as part of the coolant flush, the spec on the new thermostats (new part number) seems to be hotter. My Z06 was running anywhere from 9 to 25 degrees hotter with the new thermostat. My Z typically ran about 186* stock on the highway in pretty much all ambient conditions. After the coolant/thermostat change it was running 195* on the highway in the rain with a 55* ambient. It just got hotter from there. They replaced it again with no improvement. I ended up installing a Katech 174*. All is well now.
Don't know what to tell you about the intercooler bleed. Some shops can do it successfully and some can't. You need to question them closely with regard to their technique and tools.
I just had my intercooler circuit bled and the car now seems to be running cooler overall and has good power, even in the heat.
Devereaux (06-30-2023)
I’m far from an expert but sounds to me like they need to better bleed both systems.
not done correctly it would or could cause an issue as you described.
bring it back or post where you are located maybe someone on here knows of a good corvette tech to do this job correctly.
You could offer to pay more to get the original shop to try again after searching this forum on the proper procedure etc, give them a copy as I’m sure money isn’t an issue for you in this situation.
sorry to hear this.
sorry to hear this.
Harbgrogan (06-22-2023)
Received 8,958 Likes
Bill
JerriVette (06-23-2023)
Start with checking fluid levels. Is the main engine coolant tank full? Looking down in the pass front, find the intercooler expansion tank. It should just have two tiny airpockets in it, about a tablespoon of air each. What's it look like? I'd be shocked if it were well bled based on what I've seen.
Tank is full. Took it back to dealer and they kept it half a day working on it. Ran awesome all weekend, cooler than it’s ever been but we were up in a littler cooler weather.
Today was 116 and a was running it a little harder, got to 228 with 235 oil… Is that right with the ambient temps? What else can I do? Will doing the 2019 radiator help? Don’t want to throw money after hopes… You hear all the overheat issues with these, but that is suppose to be tracking… How I am running this with spirited daily driving?
Thank you again!
Thank you again!
Thank you again!
Thank you again!
Track overheating occurs when running hard with minutes (not seconds) of wide open throttle or very near wide open throttle operation with engine rpm running between 5500 and 6400 rpm. The only time the throttle isn't wide open is when the right foot is used on the brake pedal when the driver lifts off the throttle to slow the car slightly or to throttle steer by inducing trailing throttle oversteer.
What are the temps when you put the car in cruise at 80 mph and drive it that way for 10 or 15 miles? That will get the temps into a steady state.
Bill
Temps will go down to 210-215. If I drive it the way I want, in manual, they go right back to 225-235. If that is what I should expect, then all good.. but right now I’m not having much fun worrying about it. Feels like I have a really expensive show piece.. Like I said it ran awesome this weekend in 90 degree temperatures. Maybe it’s the nature of this. I’m used the my LS cars @ 210-215.
I would ask the dealership if they changed the thermostat as part of the cooling system service you purchased. If they did, based on my experience, the car will run considerably hotter with the new thermostat.
