Engine and Supercharger coolant
USMC (retired)
Questions for everyone regarding replacement of coolant on the 2019 M7 C7 Z06.
1. Looking to replace the engine coolant with the VP Stay Frosty-Hi Performance Formula Coolant and would like to know if anyone has done it?
2. Can I use VP Stay Frosty-Hi Performance Formula Coolant for the supercharger cooling system?
3. Has anyone installed the SYNERGY C7 CORVETTE Z06 BUMPER EXPANSION/WATER TANK (both left and right) from Synergy Motorsports?
4. do you think the bumper expansion tanks will help with Florida heat driving and a few HPDE?
Not sure about the synergy setup Im running these and havnt had an issue with overheating at all. The summers here are no slouch lol.
https://www.montmotorsports.com/cpr-...changer-lt4/#/
https://www.montmotorsports.com/cpr-...vette-z06-lt4/
-Rich
-Rich
Yes you can run that in the supercharger system, BUT the original Dexcool should be fully flushed and cleared out before using / don't mix the coolants. Another option that wouldn't require a complete flush is a wetting additive, like Redline's Water Wetter. In either use, GM suggests 40% coolant, 60% water mixture, not the normal 50/50.
A more beneficial thing regarding intercooler efficiency would be ensuring its fully and correctly bled of air. Check your tank in the passenger front, and if there's an air pocket there bigger than a two tablespoons, the system needs bled.
USMC (retired)
Thank you very much atljar for the info. Below is what I found in VP site:
Stay Frosty Hi-Performance formula is for high-performance engine drivers who don’t necessarily need all the benefits of a water-based coolant and prefer better freeze protection. We formulate Hi-Performance with a 30 percent mix of propylene glycol to 70 percent water. Propylene glycol is non-toxic, unlike ethylene glycol used in many other coolants. The 70/30 mix also reduces viscosity. The lower the viscosity in an engine coolant, the better it flows through the radiator tubes. Finally, Hi-Performance allows for a more efficient transfer of heat. In fact, you may be able to run a lower-octane fuel and save money.
USMC (retired)
Rich, long time no chat.
I have the CPR expansion tank already and looking to do the H/E next, but have purchased the in the bumper tanks to increase coolant capacity and hopefully help more.
RichAshley-Black99 (12-07-2022)
dar02081961 (12-25-2022)
USMC (retired)
Yeah man its been awhile send me your numnber and Ill give you a buzz to catch up.
-Rich
-Rich
DC.
In my situation, freeze protection is not an issue.
I do not use DEX COOL.
I use 2 bottles of Justice Bros "Protector" and 2 bottles of Justice Bros "Rad Cooler" in the rad and SC system each.
Distilled water also with blue dye in the rad and pink dye in the SC, to identify/isolate leaks.
Agree.
Water is the best for heat transfer.
A completely/properly bled system is essential for the track. Not for the street.
Agree.
USMC (retired)
Received 8,958 Likes
NInja, thanks for the input. Heat Exchanger will be installed and the radiator and supercharger drained/flushed then replaced with the VP Stay Frosty-Hi Performance Formula Coolant. I had purchased the VP during their Black Friday sale and I was fortunate to receive the 30% off. It was a lot of gallons. I hope 12 gallons is enough to do both the radiator and supercharger.
As for a Propylene Glycol based coolant read the following information as it may surprise you about its value as an automotive coolant: https://www.dynalene.com/propolene-g...hylene-glycol/
I suspect the added cooling capacity of the product you have purchased is due to the 70% water content. When compared to Dexcool at a 60% water content (what GM recommends for stock engines) there may be no added advantage and definitely a detriment if compared to Dex which is mixed at 70% water content.
Bill
USMC (retired)
12 gallons is more than likely enough to replace the coolant in both systems. The engine cooling system takes about 11.8 quarts (~3 gallons) and the stock intercooler system takes about 4.5 quarts (1 gallon). Adding the expansion tanks would maybe add another 2 or 3 gallons. If you have a 2019 A8 with a larger radiator (heavy duty cooling system RPO V08) the engine cooling system capacity is increased to 12.7 quarts.
Bill
Bill
