Gates belt size help
2nd Gear
Hey guys I need some help. I searched but cant seem to find the information. What Gates belt are you guys running with a 2.30 upper and 9.45 (17%) lower? I'm sure its listed in some post but like I said, I couldn't find it in a search.
call juiced motorsports, tell them what you need and they will hook you up
The stock size belt works fine, that is what Cordes Racing suggested and I am using. I found one belt that was listed as 10mm smaller, but when laid with the OE belt it was the same exact size.
