*Updated* 3rd round of mods for max effort lt4 build
I currently have the following mods on my car
5"intake
Soler zr1 tb
2.3 upper
100 mm idler
13% lower
Kong ported blower
Cordes hx
Cordes expansion tank
Mighty mouse wild catch can
Jms voltage booster
1 7/8 lt headers
3 or x pipe
dsx flex feul
mti cam kit with 32% fuel lobe, vvt and dod delete
Arp head studs
My next mods are
LMP LT4 lid
ARH 2" LT headers and 3" OR x pipe
Alky methanol system
30% DI injectors
Dsx aux lowside
Cordes trunk tank
Nw 103 tb
Frankenstein Ported Heads
Supercharger cooling manifold fittings
Also tune for e. I didn't have enough fuel system for e before
Hoping for 800 plus wheel.
Made a few changes since last post. Going trunk tank instead of chiller. Added the 30% injectors. Also added 2" headers
And made a few more, but this is it! Added Frankenstein ported heads also.
****UPDATE**** 3/15
Finally got the car back together. Had the first start last friday. Still needs an alignment and tunning. I'll be sure to share the results when shes done.
****UPDATE**** 8/5
I drove around with the car on a street tune because my tuners dyno speed sensor went out. After that I was working allot. I finally got some time off about 5 weeks ago and got it tuned on the dyno. It netted 790 WHP / 798 WTQ with an SAE correction factor on a 93* humid day in south Mississippi. The STD correction factor (which I wanted to know because that's what allot of these shops us on youtube) netted 823 WHP / 836 WTQ. I'm very happy with the results of this build, however I already have the 18% lower at my shop and sending my blower back to Kong for his stage x port job. I plugged off one of my 15mm meth nozzles because I didn't need it yet. I fill the car up with pump E85 and the fuel system holds up great. I'll need to use the second 15mm nozzle when I put the last 2 upgrades on I'm sure.
The Kong stage x is supposed to add 50 HP to his normal port, and going from a 13% lower to the 18% lower I'm looking for about 900 wheel hopefully.
5"intake
Soler zr1 tb
2.3 upper
100 mm idler
13% lower
Kong ported blower
Cordes hx
Jms voltage booster
1 7/8 lt headers
3 or x pipe
dsx flex feul
Arp head studs
My next mods are
LMP LT4 lid
30% DI injectors
Dsx aux lowside
Cordes trunk tank
Nw 103 tb
****UPDATE**** 3/15
****UPDATE**** 8/5
Man that thing has to be some fun just to drive normal around town. I love the torque they have with the stock blower. I have 18" MT ET street R's on the back and it hooks pretty good. Have to let it bit in first but after its solid. I hope to be around those numbers after this next upgrade.
Congrats on your car man, that's bad ***.
Wicked fast on the street with all that torque available right off idle. Running 19" R888R and they handle it surprisingly well outside of first gear. I secretly wanted to hit 900. With some Ignite in the tank and a cooler day I imagine I'm there no problem.
Similar setup as samwint above..
Lots of Cordes parts- Stage 3 cam, low side, 5" intake, heat exchanger, and expansion tank
-Katech 103mm TB
-Jokerz full tilt port with the tall lid/bricks (car is a 16)
-2.3/9.06 pulleys
-Ported stock heads
-Kooks 2" no cats
-Alky control dual nozzle
-DSX flex sensor running full pump E85
I'm probably forgetting something but that's the bulk of it. No track time for me, car lives on the streets.
-Katech 103mm TB
-2.3/9.06 pulleys
-Ported stock heads
-Kooks 2" no cats
