2016 z06 all 4 oem shocks gone-advice?
Hi experts, I went to get my oil changed at my trusted garage and they showed me the oil leaking from three of the four shocks at 29935 miles! What the heck? Four one shows smalls leak starting.
Oem shocks at dealer will be $675 a piece plus install. Any suggestions on replacements? I don’t track but drive aggressively in the mountain corners we have here.
thanks for your input! Stay healthy! Al
Take some pictures and post them up. Per specification they can show oil on the exterior. Whether this is normal or they are shot will depend on the amount of oil.
Do a search, the bulletin has been posted before.
Is “your shop” experienced with the latest GM mag suspension?
gonzala (07-23-2020)
I have been told these weep and it is normal. 3 out of my 4 are weeping as well. No oil on the ground and my dealer says a warranty would probably be denied. My car has 65,000 miles.
Interesting Comments
The passenger side front is weeping badly along with the back right Front driver is very slight and driver back is staining the shock it self.
no oil in garage which is stays For days between rides but the wheel has accumulated some oil stains and on the “arm” he said. He showed me and I should have taken pics when on the rack.
maybe I’ll take it to the Chevy dealer where we have a Corvette specialist. Thanks All.
Thinking of just that ...
we are researching after market options but I want the ride control to still work through the ****. I was told if you get those upgraded suspensions shocks with colivers, it would not work with the drive mode selector. Is this correct? Thanks
The following 3 users liked this post by BrunoTheMellow:
You can buy delco replacements for about a 1/3 of that cost if you shop around
The following 2 users liked this post by atljar:
dar02081961 (07-28-2020),
I have Coilovers and while they are badass at track I really miss the mag ride when on the street. Yes Coilovers have the adjustable heights but anytime you mess with height you need to realign again so no I would say stick with mag ride. I’m fixing to go back to my mag ride now that I’ve accomplished everything I set out to do with car.
The following 2 users liked this post by LuckyC7Z06:
gonzala (07-23-2020),
need-for-speed (07-22-2020)
Great idea. Maybe from a GM parts vendor here
I may use cultrag vendor I’ve purchased from them and they are pretty low in cost for GM Oem stuff. Any other suggestions for vendors?
+1 on Cultrag he has been taking care of me for a years now on all my GM vehicles. Best customer service hands down that’s why I always deal with him.
You can buy the shocks used super cheap.
gonzala (07-24-2020)
Figure out the OE shock number you need, then figure out the AC Delco replacement number. Google the AC number
GM parts show cheaper than Cultrag. Would love some help in this AC Delco option if it’s better or OEM. I know they use the AC Delco oil filters. Thanks
