Mobil 1 European car formula
I am new here but not new to internet forums and I realize that it's a touchy subject.
I'm in south Florida where daytime temperatures here are year around above 80 and hotter in summer.
Is 0W-40 still the way to go? What about track days? Filter? GM or Mobil 1?
I'm always looking to do better than factory recommended if possible.
Received 1,373 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
Zinc and Phosphorus are anti-wear chemistry.
Zinc and Phosphorus can cause cats to fail-after many, many miles IMO.
Zinc and Phosphorus ppm is less in ESP oil than in the European Formula.
Zinc and Phosphorus ppm is higher in Racing Oil, what does this mean
—————————ESP—-European ———Mobil 1 Racing 0W-50
Phosphorus ppm 900——-1000 ——————1750
Zinc ppm ————990——-1100——————-1850
Below is the old Mobil 1 add recommending European Formula 0W-40 for Corvettes.
It’s good oil. I ran it in my 08 Z06 and then in the 13 ZR1 for years, had zero cat problems.
The following 3 users liked this post by BearZ06:
Doesn't matter where you live, the new 0W-40 will give you plenty of protection. Only use the new 0W-40 Mobil 1 ESP formula. The new formula is for street AND track. I'd use the OEM filter. Mobil 1 isn't that great of a filter. It's a cellulose blend media and not even a full synthetic filter like the Fram Ultra filters. The OEM filter is more than adequate for how often we all change our oil. We aren't going to go 20K miles between oil changes. As long as the OEM filter can function for 3K-4K miles, I am good. GM's OEM filter has the proper pressure specs that other aftermarket filters don't have. That's another concern of mine. I also don't want any warranty issues where GM will blame me for using an aftermarket oil filter.
If you're having trouble finding the oil look here.
https://www.speedwaymotors.com/Mobil...ts,371931.html
https://www.speedwaymotors.com/Mobil...it,386340.html
OK, $105 for oil + filter is a bit more than whatever a regular trip to Autozone would be - say two gallons of Mobil 1 and filter, around $70-$75... but it's only $30 more, which is less than a tank of gas, and keeps the vehicle exactly (my car is new) to manufacturer's specs for warranty. I'd also remind that we're talking an insanely powered supercar, and as Corvette guys, we do expect our vehicles to be maintained at regular prices... OK, so $105 vs. $60/$70. But can we imagine an oil change on some other exotica that would cost way more than that.
Example: in writing this reply, I just Googled 'oil change lamborghini huracan' and saw prices run a few $1000 (!!!!) for an oil change. And then I saw this video -
I love the fact that for our Corvettes, an "expensive" thing is $105 worth of oil for an oil change. I'll take that any day!
JKU007FL (05-14-2020)
I use extra extra extra virgin olive oil with 'extra' zinc. I also put it on my pasta to help me resist a virus. I read on the internet that zinc helps our defense mechanism. My car is full of mechanisms so I figured....
CJ Willys (05-14-2020)
Don't use the European Formula. That is what is used in Corvettes in Europe and this is America!
You have to check the oil level with the oil temp at or above 175 degrees. You have to shut the engine off and let the engine sit for 5-10 minutes and then check it. You can't check the oil level when the engine is cold.
Here's a lubrication spec from 2008...and it's waaay out of date, these oils would not comply with today's components. For this reason, I would believe the GM engineers know what they're talking about, who knows, but as an owner, I follow what they recommend.
http://oa.upm.es/14340/2/Documentaci...ns%20Guide.pdf
Why take a chance with aftermarket oil?
#33
I believe most people in the industry believe that Caterpillar manufactures some of the finest diesel engines in that manufacturing niche. In the last few decades, they have become very specific as to the spec of the powertrain oils used in their equipment...so specific and concerned that they require powertrain oil samples be taken by the owners and run by the Cat dealer so the results can be fed back to Cat's Engineering group.
#35
#36
I seem to remember Car and Driver or was it Road and Track testing the new C7. LT1 blew up because of a failed oil filter, probably Mobil 1 or some off brand.
#38
I remember that! If that happens and GM sees an aftermarket oil filter, they automatically deny the warranty claim and you are left holding the bag. If the engine blows up and I have the Delco oil filter, they have to cover it and they will!
#39
I dodged the bullet. Ran the **** out of my '16 Z51 M7 coupe. Had it to redline before it had 30 miles on it, on the track at Bowling Green before it had 100. Mostly ran Mobil 1 5w30 but also 0w40 European. Ran Wix, PF64 and Pureone. Autocrossed it a bunch, spent a lot of time bounching off the rev limiter. Got a Cow tune and Vararam CAI so warranty is no longer a concern.
#40
I called Mobil 1 and they said definitely use ONLY the ESP mobil 1 and never the european formula in a Corvette. No written warnings
Oddly, the european version is in the stores and all over e bay. I think its easy to choose the wrong oil if you are not paying attention
Lots of parts store people and some techs don t know the difference. When I go to the dealer, I only have a corvette certified tech work on my cars and I talk to the tech and watch him. Shops that say you can t go back I don t use.
Bottom line, I am responsible for my cars and I want everything done right. I am coming up on 10000 mile Oil and filter change on my 19 zo6. I just ordered the correct Oil and filter off e bay. Will use race ramps and some wood and I know that the job will be done right.
Save the wave, John
Save the wave, John
