X-pipe only?
Regarding the Borla Xpipe 60548 that doesn't replace the secondary cats, I don't know who would want to spend hundreds of dollar to buy this to replace just the mid section of the exhaust after the secondary pipes as the factory system already has an X crossover??? Am I missing something? Or does someone makes a set of bypass pipes that bolt onto the gap left behind after the secondary cats are removed to make up for it? Or will I have to find a shop to make me a custom bypass? I'm really bumped out that I didn't know the only Xpipe Borla sells now is the useless version.
Location: NNCC No Name Car Crew Owned 1 C2, 2 C3's, 1 C4, 3 C5's, 1 C6, 2 C7's Now '81, '86, '03.
Received 3,941 Likes
2023 C3 of the Year Wnner - Unmodified
cant beat the sound,extra HP a non issue.BORLA
What's wrong with just throwing this one on?
https://www.ebay.com/itm/FOR-14-17-C...EAAOSwDvZc7DwQ
Borla is deeper. Corsa is a bit more high pitch. Just a bit more. Had borla on my last car and Corsa in my current car. I'd say the difference in tone is like the Corsa makes the car a little less truckish.
I tried one from that vendor(speeddaddy) and had problems getting it to line up correctly. With a little work it may have fit but I decided to return it. I was only able to measure the ends of the xpipe they sent me so I don't know if they all are the same. But the rear end of the xpipe had about 1/2-3/4 inch shorter distance between the inner wall of the exit pipe ends compared to the stock xpipe.
thelastday (12-19-2019)
#35
#37
I just put the stock one back on.
#39
I tried one off eBay and ended up sending it back. The picture quality and what I received were of 2 different x-pipes. The weld area was extremely bad and had holes in it. When I looked inside at the cross over section with my borescope the connecting hole was less than 1 inch and had some metal covering most of the hole. The hanger for the rubber grommet was bent and not in the right place. Simply bad quality.
I couldn't find a Borla so I got a Corsa x-pipe. When I looked inside at the cross-section the openings were extremely large, the welds were good and no excess metal inside where the cross-sections are. It slid right in and clamped down with no problems. The 3-inch end is tapered down to slide fairly tight over our exhaust pipe.
Sounds very good and am happy with the Corsa.
Best, Tom.
You wanted sound?
Best, Tom.
You wanted sound?
