Sponsored by: GEM Motorsports
New Gen 5 LT DI injectors - +45% over LT4
Old 07-18-2019, 09:55 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Default New Gen 5 LT DI injectors - +45% over LT4
Our first 100% XDI manufactured and tested DI-Injectors are designed for the new GM LT series engines. With a 45% increase in flow over stock LT4 injectors, these supply the required fuel flow for high horsepower applications without the need for auxiliary fuel systems. These injectors are based on the original GM LT4 injector, which makes them a perfect drop in solution. Most of the ECU Injector characteristics stay the same.
Every Injector gets tested at 100bar and 200bar on OEM testing equipment at XDI. Every set gets flow matched to within ±0.5% at 100bar and 200bar fuel pressure !!!
Testing on several fully instrumented engines (8x O2, 8x EGT) done by Katech Inc. has shown unequaled results in terms of cylinder distribution, repeatability and stability at pressures up to 3000psi. Tuning changes required are minimal, offsets and current driver parameters stay the same. The injectors are E85 compatible and have so far been tested up to 1308bhp on engine dyno and 1067whp on roller dyno (Ignite E90).
Maximum Fuel Pressure is 220bar / 3200psi.
Straight E85, 1067whp GDI only !!!
no meth, no PFI, no extra ECUs, no wiring, full control, full OBD Diagnostics.
High horsepower GM Gen V V8 and V6 direct injection engines including LT5, LT4, LT1, L86, L83 and LV3
E85 conversions of GM Gen V V8 and V6 engines
2014+ C7 Corvette LT1
2015+ C7 Z06 Corvette LT4
2019 C7 ZR1 Corvette LT5
2016+ Camaro SS LT1
2017+ Camaro ZL1 LT4
2016+ CTS-V LT4
2014+ Silverado and Sierra with 4.3L LV3, 5.3L L83 and 6.2L L86 engines
2015+ Suburban, Tahoe, Yukon and Escalade with 5.3L L83 and 6.2L L86 engines
rated static flow rate: 25.6g/sec at 10MPa
– 67% more flow than production LT1/L86 injectors (15.3g/sec)
– 45% more flow than production LT4 injectors (17.7g/sec)
– E85 compatible
maximum pressure:
200bar / 2900psi (tested rock solid on engine and roller dyno)
240bar / 3500psi (under perfect conditions, no pressure pulsations)
Tuning Support: HPT
https://store.katechengines.com/xdi-...s-45-p819.aspx
__________________
Contact:
(e) zach@katechengines.com
The following 3 users liked this post by Katech_Zach:
ajrothm (07-18-2019), edster75 (07-19-2019), houdini13 (07-20-2019)
Old 07-18-2019, 11:29 AM
ssmith512
ssmith512's Avatar
Game changer!!
Old 07-18-2019, 12:56 PM
rjacobs
rjacobs's Avatar
Are you all going to produce a better HPFP(similar to the Lingenfelter big bore pump) or only the belt driven one?
Old 07-18-2019, 01:41 PM
Katech_Zach
We don't have any plans to do so.
Old 07-18-2019, 02:04 PM
Pacembellum
Pacembellum's Avatar
You guys are absolutely killing it. I think the car is going to Michigan at some point. E85 build would be too cool.
Old 07-18-2019, 04:45 PM
bc928
bc928's Avatar
This good news. Still need more flow though. Low side for volume. High side for pressure.
Old 07-18-2019, 05:00 PM
Arben72
Arben72's Avatar
Does the stock high side keep up? (Obviously with a cam). This is great though.
Old 07-18-2019, 07:58 PM
DTOM
DTOM's Avatar
C7 of Year Finalist (performance mods) 2019
What power level are the stock LT4 injectors maxed?
How about the stock fuel pump for 2019?
Old 07-19-2019, 11:56 AM
BooSSted
BooSSted's Avatar
1308bhp on the LT4 motor? What other controls are we considering? If on the LT4 was it on stock cam, and fuel system, just drop in injectors?
Old 07-19-2019, 06:29 PM
atljar
atljar's Avatar
45% math says about 900hp. Sounds reasonable
Old 07-19-2019, 06:30 PM
atljar
atljar's Avatar
Zero chance. I would think it's fair to assume unlimited low and high side flow, and then the injectors tap out at 1308. So an aux pump on the low side and likely katech belt driven high side
BooSSted (07-19-2019)
Old 07-21-2019, 04:05 AM
BooSSted
BooSSted's Avatar
Any real world direct testing on street app LT4? @Katech_Jason
Old 07-22-2019, 12:48 PM
Katech_Zach
Yes, we have been running these in our internal builds for some time now.
Old 07-22-2019, 02:11 PM
K1600GT
K1600GT's Avatar
Sub
I run out of fuel and pulse width at E40. If I understand this is a drop in and go or do I need bigger fuel pumps? Would be nice to run at least E60.
Regards
Old 07-22-2019, 02:12 PM
bc928
bc928's Avatar
Originally Posted by K1600GT
Sub
Regards
At what power level do you run out?
Old 07-22-2019, 02:34 PM
K1600GT
K1600GT's Avatar
685 whp on dyno.
Old 07-22-2019, 02:45 PM
K1600GT
K1600GT's Avatar
I had it a little off
To New Gen 5 LT DI injectors - +45% over LT4
Old 07-23-2019, 09:37 AM
Katech_Zach
Sub
Regards
You will still need low side and DI pump to supply your specific power level on E85.
Old 04-16-2021, 01:12 PM
Commandercorvette
Commandercorvette's Avatar
Anyone have info on how much the stock lt5 zr1 injectors flow ?
Old 04-16-2021, 01:19 PM
Pacembellum
pretty sure they’re the lt4 injector because they run port injectors for extra fuel
Quick Reply: New Gen 5 LT DI injectors - +45% over LT4
