Katech's new twin heat exchanger system for C7 Z06
My only wish is if it had the Z06 shaped honeycomb grille I love that look design wise.
Dang that is nice trans.
Really nice solution! Can’t wait to see some more data on it!
Do you have any dimensions of the cores used? Also, and this could be deceiving from the pictures, it looks like there is more room for a taller core? Is that correct?
Premium Supporting Vendor
The heat exchanger is pretty maxed out in the available space, leaving some room for a hanger.
Is the kit also compatible with the stock (stage2/3) aero in front?
Yes, it would work with stock level 2/3 aero, although we recommend an oil cooler upgrade for full benefit. Either our oil-to-water that goes in line with the lower radiator hose, or our splitter with oil-to-air cooler option, or both.
edster75 (06-27-2019)
It will not work properly with a ZR1 conversion bumper without proper ducting.
