Magnuson 2650
Magnuson 2650
Anyone have this on their beast yet? Looking to see some videos....
I ordered two.... One for my Trackhawk... and one for my z06... Look forward to sharing with you guys the outcomes!
Supporting Vendor
we install the one here on the 18th.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
Supporting Vendor
Facebook Post
should
bbbvettes.com (06-16-2019)
not sure yet. however the lt5 sure does, 2300, and oem blower with our 5'' cold air intake
https://www.facebook.com/Cordesperfo...2111376384188/
should
should
Cordes Performance Racing (06-09-2019)
My buddy is stock cam and heads just 2300 and a pulley. He is out of fuel at this point. I would imagine out the box you would need to upgrade the fuel system which is a pita in these cars compared to old gens.
Supporting Vendor
Supporting Vendor
😁 This thing is massive. It's 3" wider than a heartbeat 2300. Will require valve covers for sure so budget for that.
chevyfanatic (09-06-2019)
Supporting Vendor
Supporting Vendor
Magnuson 2300, our 5" cold air intake, our heads/cam package, 103 mm throttle body, upper/lower, bolt on's, our fuel system, e85, meth, our expansion tank/ice tank, our heat exchanger. Car made 830 in 90 degree weather.
Supporting Vendor
$1000 more. They don't come with pulleys though so add $80 there. Also factor in valve covers so $500 for some moroso's (least expensive offering) than you need a welder to add pcv fittings onto the covers and hardware to mount coils.
Shostopper (06-11-2019)
Any ability to run port injection or is that basically out due to the size of the blower?
Supporting Vendor
If you could you'd have to hang the injectors off the side at a terrible angle which I absolutely do not like. And than things get even more jam packed with rails, fittings, line, etc.
Thanks I still plan on having you guys build my car when I get the funds.
Cordes Performance Racing (06-11-2019)
Supporting Vendor
