Toyo R888R on stock Z06 wheels
#163
Has anyone tried 305/30/R19 for the fronts? Looking to get more grip in the front.
Once of the guys this weekend was running 315/30/R18 and 335/30/R18 on his Vette for road course use.
#164
I have a 295/30/19 up front and this a decent compromise street/track size that wont mess with the factory stability/traction control calibrations.
That's on an OEM size front wheel (19x10) a 19x10.5 or 19x11 wheel would probably improve grip a little more but may rub a little depending on ride height, spring rate, etc. etc.
A 305 is too much for a stock 19x10 wheel and would probably reduce front grip (in my opinion)…. now on a 19x.11 inch wheel.....it would probably help.
#165
I ran 305s on a 10" wheel on my 2013 Mustang GT and had no issues. I'm not sure how much difference it makes being up front, but I had even tread wear and all that. Same profile, though an inch bigger wheel. 305/30/20
#166
Have pulled the trigger on new rubber and wheels. Am going with the R888Rs all the way around. 345/30/19 on back and 295/30/19 up front. New wheels are Cray Astoria gloss black with mirror cut face. 19/12 in back and 19/10 up front. I have an Arctic white 2016 Z06 and am hoping the mirror cut on the wheels provides a complementary color to the body color. Will post pics when installed. Will keep the OEM wheels and MPSS tires for long road trips.
ernhart333 (02-01-2020)
#167
#168
Where are you buying yours?
Oh here are my rims and my car is at Katech getting the stage 3
These are the 19/20 Forgeline EX1's from Gerry at CW4L
Weights OEM vs Forgelines (Forgelines on the left OEM on the right)
Note the Forgelines with the OEM caps I machined to fit the Forgelines.
Fronts: OEM = 28lbs Forgelines = 24lbs
Rears: OEM = 33lbs Forgelines = 25lbs (this seems like a huge savings)
#170
Wow! What a spectacular ride. Those wheels will look killer on the Z car. Significant weight differential between OEM and Forgelines. Are you going 325/30/20 on the back?
#171
I hope so, I will be getting my Toyos soon and Walmart seems to have the best price I have found so far.
Note the Forgelines with the OEM caps I machined to fit the Foreglines.
#172
Yes sir I'm going with the 325/30R20's rear and 295/30R19's on the front.
Here at the Walmart in Pa I got a price of $475.90 each rears and $335.73 for the fronts
Are these close to your prices?
#174
Yes, price I was quoted is $500 for the rears (345/30/19) and $345 for the fronts (295/30/19)
#175
#176
#179
#180
Warning Warning Will Robinson! Reconsider having Walmart install these. on your rims! Don't say you were not warned !
