A8 shudder update
Received 3,448 Likes
Talked to two dealerships and the Borla X pipe is no problem. In fact my son had the dealership install his when they did the courtesy delivery.
I had my tranny flushed yesterday and all I can say is "thank goodness for this forum!" I called the dealer last week to make an appointment to have the tranny flushed due to the shudder that I get going up the hill to my house and on the highway. They said they would look at it first to determine the problem. I also scheduled the programming upgrade to my suspension. At first the woman on the phone didn't know anything about the upgrade. I explained it to her and she said she talked to a technician and he was aware of it.. I asked her if she needed my Vin # and she said she was all set, they had it on file. I get to the dealer at 8:00 am yesterday and the service person wasn't aware of the shudder problem and didn't know anything about the suspension upgrade. Luckily I had the shudder paperwork that I printed from this forum with me so he could figure that one out. He said he would check on the suspension upgrade. Ten minutes later, he comes into the waiting room and tells me they will reprogram the tranny first to see if that fixes the problem and he couldn't find anyone that knew about the suspension. He leaves and I did a quick google search which brings me to the forum and I give him the GM part number he needed. He comes back a little while later and tells me they can get the program and the cost would be $350 plus an hour and a half of labor to install it. I told him that it should just be $350 and the labor is included. Another search of the forum and I show him where it says the cost is $350.
He comes back a few minutes later and tell me he is all set with the suspension upgrade ($350 plus tax) and that they are going to flush the tranny. He wants to know if I am going to pay for the tranny flush. I said it is covered under the warranty. He says it isn't and I have am past the warranty. I have a 2015 with only 17k miles on it. I told him it should be covered under the 5 year/100k mile drivetrain warranty, if he doesn't want to do the flush, I can come back after the torque converter fails, problem solved. Three hours later ( I waited for the car knowing there would probably be some type of issue) he tells me the GM tech says the car has to sit for 8 to 10 hours after they reprogram the suspension and I have to leave the car there. He does this in the waiting room and I tell him this is incorrect and the car can be driven and then sit for 8 to 10 hours for the car to recalibrate. He disagrees with me and I tell him I am taking the car. Another google search which brings me to the forum and I go show him in writing what GM says about it. I get back to the waiting room and a woman asked me who was correct, I told her the forum was. LOL
What a scam. If I hadn't read about all of this on this forum, I probably would have paid for it out of my pocket. I just want to thank everyone that posts on here with this type of information. It definitely helps me.
Thanks,
Phil
Thanks,
Phil
Lol. Yep to all the above. Thank goodness for this place.
Sorry to hear that! There must be some part that TC is connected to that is struggling. It may be putting too much energy work on the TC. I sure hope they get you squared away quickly. That has to be really frustrating that the main part of the car connected to the motor is a major stumbling block for GM. Obviously they don't want that to happen, but it seems after so much time they could have figured it out. Maybe at first they thought they could just kick the can down the road, plug their ears and it would go away. I realize I could be completely wrong, but they seem to be not taking these shudder issues too seriously. Could be they are now since they indicated they would have a fix in the first quarter of 2019. Let's all hope so.
Flushing twice
Taking the Beast in to the dealer tomorrow morning to have the fluids flushed.
Dealer has indicated they will replace fluid twice this trip in.
Guys, it's fairly certain that the AFM system is a major cause of the problem, especially at low speeds around 40 mph in 6th gear, and is damaging the clutching system in the TC. GM might have a software or other fix in 2019, but for now put a Range module in. It will cost you $175 and some gas mileage but it's worth the probable avoidance and aggravation of a TC change. The system flush appears to be long term ineffective and you'll still end up with a bad TC. Mine's been replaced and it definitely cured the problem but my Range module is staying in for good.
*** Zero stars. This thing freaked out my C7 Vette, it quit shifting and was stuck in 4th gear limp mode. All my computers quit communicating, trans, abs, chassis, Ecm. It wreaked havoc on everything. Luckily it doesn't seem to have done permanent damage. Avoid this thing like the plague unless you wanna risk blowing up your $100k cars electronics.
Not sure what to do, damned if you do, damned if you don't..
Did some checking about the Range module... seems some that use these units are experiencing some bad issues with the unit. Throwing codes, stops working so have to unplug re-plug it in before will work again, causes numerous electrical issues and this one...
#33
Have been using the RANGE for about 3 years....no problems with it. Use it with a switch on the drivers side door/floor...perfect. Switch on/start; switch off/stop.
AND NO TC problems....2015 Z06 w/A8....first week production of the Z06 w/A8.
#34
#35
When I first got mine it wouldn't shift passed 3rd gear a couple of times. Stopped the car restarted and was good. Also got CEL a couple of times before that incident. Range had me send it back to them to flash it and update it and has been golden since then. That was a couple of years ago. The bugs are all ironed out. One doesn't even have to turn it off and on anymore. Just leave it plugged in at all times and no drain on the battery.
Previously when users of the device were having issues it turned out to be issues with their car and not the Range in a lot of cases.
MMD (11-12-2018)
#36
So for those that have used it and had no issues, did you order direct from manufacturer or third party?
Thinking I might go to the Range Technology website.
Thanks..
#37
Googled it, this particular response was one of many from Amazon (which had a wide variety of 1-5 star responses) however in reading more of them it appears the units sold on Amazon (and having issues) may/may not be current software version and some of the reviews warned against purchasing off of Amazon (third party).
Thanks..
Thanks..
#38
Thanks..
Thanks..
joemessman (11-12-2018)
#39
MMD (11-12-2018)
#40
