Stock ZR1 vs Stock Z06
An auto C7Z is actually slower.
In a roll race, a manual Z would be faster, depending on how far up in the MPH you're going to go.
But why is any of this a surprise? The C7 ZR1 is a monster. Makes a ton of power in the worst conditions so anything better than extreme conditions, it's actually a lot faster/more efficient. GM did not play any games with this car and learned all their mistakes from the z06. They weren't going to make the same mistake twice.
I am still waiting anxiously for the C8. If it's no bueno, i'm upgrading to a manual ZR1 ASAP!
SocalChvy (08-14-2018)
you can't be serious dude. maybe a c6 zri but a 500 hp c6z06 walking a c7z06? why do you post such nonsense?
The following 3 users liked this post by Ted P:
So who leaves the Z06 stock? The Z06 and 10k in mods and the race looks the same only the other way around! MEH!
racerx8 (08-15-2018)
well I currently own a 2017 c7z06 m7 and had a 2009 c6z06. The c6 felt faster to me.
And car and driver reports a 0- 150 mph on the c6z06 of 17.3 seconds december 2008 for a 2009 z06 . Car and driver reports 17.8 seconds for a 2015 c7z06 m7. The c7 is half a second slower . Given the c7 is a bit quicker 0-80mph. The c6z06 makes up some serious ground on the big end to catch the c7z06 and ultimately is a half second quicker to 150 mph. There for in a roll race 50 on up 150mph and then on to top speed of which a c6z is 8 to 10 mph faster then a c7z06 a c6z will stomp a mud hole in the *** of a c7z in a higher speed roll race.
And car and driver reports a 0- 150 mph on the c6z06 of 17.3 seconds december 2008 for a 2009 z06 . Car and driver reports 17.8 seconds for a 2015 c7z06 m7. The c7 is half a second slower . Given the c7 is a bit quicker 0-80mph. The c6z06 makes up some serious ground on the big end to catch the c7z06 and ultimately is a half second quicker to 150 mph. There for in a roll race 50 on up 150mph and then on to top speed of which a c6z is 8 to 10 mph faster a c6z will stomp a mud hole in the *** of a c7z in a higher speed roll race.
The Consigliere
Received 5,458 Likes
Vid is not a huge surprise.
All cam and exhaust setups are not made equal. Some guys go cheap on the parts, tuning or simply don't piece together the right package. There are cam and exhaust C6 Z06s that you will run with and there are some that will blow your doors off.
Summary is that you likely need +60whp on a C7Z to outrun a C6Z... also have to make sure you're not pulling timing, car needs to be cool...
Z06 driver clearly doesn't know about no-lift-shift. Absolutely the only way to have a shot against an automatic car. Although I believe the outcome would be the same.......especially from 100mph up.
The c6z06 does have a pretty substantial weight advantage.
Perhaps there are gearing differences as well. This would need to be verified by people who know more.
Otherwise, i think it's incredibly situational when comparing the c6z and c7z.
Z0HS1CK (08-14-2018)
