Defective K&N oil filter pic
I've changed oil for 45 years and never bought a defective filter. Till this time. Never used K&N before. Never will again. Thought it needed to be tightened but it's leaking at the nut seal. Can't find PF64s. Probably will buy a Wix.
Received 1,817 Likes
Wix is one of the most respected filters out there, among hardcore motorheads.
diverman (06-08-2017)
01Defense (05-23-2017)
Thanks for sharing!!
thanks for the info, guess ill be switching back to wix. put a k&n on this time. checked it and its not leaking. ill keep an eye on it until the next oil change
K&n
I also purchased a defective K&N air filter. The thing would not seal in the stock housing, it was a little too long. I contacted K&N and they did nothing for me. So I wasted $70 on it, however discover the BMS filter and am extremely happy with that, much better performance as well!
I have a M1-113 Mobile and the kn. Look totally different at the filter end.
I'm not sure about the K&N oil filters anymore, but I do know the M1-113 is still made in the USA.
I think Purolator invented the oil filter, this new all synthetic filter for the C7 is their best yet.
I now use this oil because it kicked a$$ (withstood heat better) in an oil test against Mobil and many other top rated brands, by the way Mobil 1 usually finishes in the top two or three in every oil test. The QS "Full Synthetic" 5 quart bottle is now green in color. I believe QS & Penn. have merged.
I've been using K&N for a lot of years on a lot of cars and have never had a problem. I suppose it's possible they changed some equipment and it's burning through the case. I'll keep an eye on them, thanks.
Are you certain it's not just from the gasket seal leaking down across the outside of the filter and collecting inside the hollow the nut cap (low point)? The oil color discoloration on the filter label makes me think this might be your issue, not the cap lug itself?
Also looks like you tightened it on with a wrench from the wrench/socket marks on the hex nut (reference paint chips on the CW direction corners).
Could have crushed the seal. I've always stuck with just hand tight (as tight as you can get it by hand) as all you should ever torque a new filter to. Nut is there to aid removal more than anything...but is probably tempting to crank on.
Google K&N oil filter leaks.
Very certain it was not the gasket. In 45 years of changing oil filters I've never crushed a gasket, left an extra gasket on from the previous filter or had one leak.....until now.
Received 4,508 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Thanks, now we all know, stay away from K&N.
The Z06 oil filter actually requires a lot of torque. I think the owners manual specifies like 22 ft. lbs. or maybe 45? Anyway - I use he K&N filter - if I hand tighten it will leak around the seal.
