2017 Z06 supercharger lid installed on 2016 Z06
I just installed the 2017 supercharger lid on my 2016 Z06. The install took about 20 minutes for the hood insulator (84016133) and supercharger lid (126703730) took about 30 minutes.
I purchased the parts from Trunk Monkey. The supercharger lid arrived damaged, because GM did not pack the bolts(which I did not order and were not on the bill of materials) in a bag. They just threw them in loose. So Trunk Monkey was great and replaced it with a new one. I also ordered the retaining clips for the hood insulator, but I used a plastic interior pry bar and got them out and they were in perfect shape. If you are careful, you can do the swap without new insulator clips.
Will the lid help at the track? I don't know. On my naturally aspirated cars I did run a plenum spacer and they seemed to help. The new lid has a lot more volume, looks badass and I don't think it will hurt. I am not going to swap out the intercooler bricks with the tilted ones.
LagunaSecaZ06 (01-02-2019)
How much more expensive would the tilted intercooler brick have cost and how much longer would the installation time have been?
You could probably close the hood with the old insulator. I wouldn't recommend it, since it would put stress on the hood and, look like crap because of the rubbing between the lid and the insulation. You would have fibers all over the engine.
Its about $93 for the insulator to do it right.
Z06NJ (12-14-2016)
The lobe length needs to be shorter to get down in the valley. That's why you get 1.7L rotors. And it's not a bad thing, they spin it faster, which is also not a bad thing. Until you get outside it's envelope, but I don't think anyone has shown that with the 1.7L yet...
If something downstream fails, like a rotor, it might. But I can't personally think of a practical failure that I'd expect that I could tie back to the lid.
People need to stop thinking they can void an entire warranty - you can wind up with specific warranty claims denied, but that's different.
BlackBandit (05-13-2020)
The LS9 and LSA (I think) look like they've got a bread box on top of the engine because the blower sits ON the engine rather than IN it.
Shorter lobes -> down in the valley -> lower motor -> lower hood -> lower center of gravity -> all goodness.
They couldn't get it down into the valley, and you wound up with a hole cut in the hood and a (sorry) cheezy plastic window looking at a cheezy plastic cover (good engine under all that though).
Now that they realized they don't, they revised the hood pad and the blower is able to take up that extra space.
Win-win, unless you're a pedestrian I guess!
So youre saying lobe diameter is the issue not length
Yes the original was when they (INCORRECTLY, it turns out) thought they needed to meet the european pedestrian crash impact standard. That also requires a certain gap between the hood and the engine.
Normally I'd say it's all about girth and length in proper proportion, but when it comes to blower lobes, no, I just thought shorter. Sure there's a diameter limit too, but all I really claim to know is that the TVS-2300 didn't fit so they went smaller with something that did fit. I wasn't in the room!
