Stage 2 spoiler extensions.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Unless the car is tracked, is there any benefit at normal highway speeds from adding them ? I'm trying to determine if they would create enough down force to aid in wet weather driving.
Purportedly the Stage 2 package results in a 400% increase in downward force. Not sure what speed is necessary to hit this mark, but the spoiler extensions are certainly more than an appearance mod and "might" offer better wet weather driving traction.
Note: the Stage 2/3 side shirts and Stage 2 splitter w/the smaller winglets would also be including in this assessment.
NCM Lifetime Member
This is going to be interesting. I do know that in the rain, the rooster tail from the stage 1 is kind of cool. I can only imagine what it would be like with the stage 2 pieces installed to the base spoiler. The other side effect I noticed is that it kept cars from crowding me on the highway. They did not like the spray ..............
I have Stage 3 CF all around. I have achieved 27mpg straight highway driving from fill on the highway and go EXACTLY the speed limit, but average 21-24 with my city/hwy mix driving. Conversely, I have driven at speeds conducive to the ground effects providing down force through enthusiast routes like Angeles National Forest. Lastly...the look is amazing...
NCM Lifetime Member
So how badly does the center wicker bill reduce vision ?
2017 C7 of the Year Finalist
Without the center wicker, it is like a small port hole. Going up a slight hill you see pavement behind you, going slightly downhill you see sky, and level ground you don't see much. Imagine sitting in this car and looking out the rear view. That view is reality.
Z06NJ (09-29-2016)
NCM Lifetime Member
Well, that shouldn't bother me then. I've driven semi-tractor trailer for the past 50 years so i'm used to side vision only. I rarely use my rearview mirror. In fact, with the camera now in the dash, I never use it for backing. I do thank you for the response.
My car is a Aero 2 car. I have driven a ton in the rain and with the MPSS no issues. Select WET and drive reasonably for no issues. With wide tires hitting any major water is going to be a bad time if you are hauling a$$.
Yeah the rooster tail is epic behind the car. No one rides behind me. Also the wet tires throw a ton of rocks. (Have had friends behind me complain.)
Reminds me of this scene when I look out the rear view mirror.
NCM Lifetime Member
So true. Can't wait to get the wicker bill and stage two extensions installed ................... Come on rain ................
