Wickerbill center bolts
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
The moment I changed out from stage 1 to stage 2, I took the original bolts and put them in a marked poly bag. Then put them in the box along with the stage 1 end pieces.
Turn 12!
NCM Lifetime Member
Some of the Ace Hardware stores have them in a black chrome button head allen screw. They also carry a matching flat washer of the correct od and id. I am seriously thinking of switching out all of the factory torx screws to them.
regular length so they will all be the same... Can use the fiber washers that come on the OEM's
NCM Lifetime Member
Yup, those are the ones.
Here's some of the longer bolts that I used on my 2017 Z06 to attach the center wickerbill bridge. Very close match to the now $120 GM bolts.
https://www.ebay.com/itm/Bolts-C7-Z0...item5b40e5a4b7
From Amazon depending on what length you need. They are M6 x 1.0 thread x whatever length.
and
and here is the thread with both the Ace Hardware info and the Amazon info:
https://www.corvetteforum.com/forums...3-spoiler.html
and
