Blendmount mirror suspension for radar....anyone?
Thinking of giving this a try on my Z06 with an Escort max 2. Anyone out there with experience to recommend for or against this?
Monkey D. Luffy (09-02-2016)
I love the Escort products, but it gets very hot here in OKC and the suction cups just don't work. The blendmount is a much, much better way to go. (The best fringe benefit is that the unit is completely quiet now. With the suction cups, you can get a ticking noise from the detector mount.)
I don't know if it's just me or not. But the blendmount I got for my Z06 seems to be falling off a lot. It doesn't really fit well around the rear view mirror and it's already fell at least 5 times. I've tightened all the bolts to the max.
twoweeled (06-12-2023)
I bought one back for my stingray. As of late it will not stay put. I can tighten the screw that keeps it from point towards the console. But it will not hold I think a little loctite should work to hold it up.
I found that you really have to be sure the two clamp halves are aligned well. If they are offset at all, they don't hold.
Corvette fan
I had the blend mount on my C6Z. Worked OK but vibrated a lot. So, I went with a mount that sticks to the back of the mirror for my C7 with 3M adhesive. More stable in my experience than the blend mount.
http://www.glteplaques.com/products/...q2sPCXCtt20r1/
rw99 (02-08-2017)
Yea, this has been an issue for me as well with my install. There is not enough room behind the mirror to work it in right it seems as well. But I did finally get it very tight and it's been right for a while then with driving and bumps it loosens up. Very frustrating. I put some double sided tape on the mirror base so to tighten into something to grasp besides another hard surface (plastic or metal whatever it is) the bracket does not stay put for the long haul. It's great when it's solid. Tapped into the mirror looks great too. Good luck!
I don't know what you guys did, but my blendmount was rock solid in my c6z, gt350, accord, and c7z. I have nothing but good experience with blendmount and mirror tap
T have the radar in place.
Anyone think a cop who pulls you over is more likely to ticklet you if he sees a radar detector?
