2017 Z06 Spotted in the Wild! Pics Inside!
#101
Yep.
Sadly, retrievers (be they Golden or Flat Coated) can't keep their big traps shut.
Flats give the info away cause they're just nice that way, Goldens, because of their greed for dog toys, make you pay for it
Jimmy
Jimmy
#102
You were obviously right back then, NineBall. One question though: you point out in that post that part of the problem is the Stingray front fascia and its limited airflow. How can the problem be fixed/improved with the same fascia? Maybe Jeremy & John can offer some speculation?
It is pretty evident that they are working on a new C7 nose though, based on the recent pics of the test mule driving around with camo'd front clip. We can make out vents next to the center grille opening, similar to the 2016 CTS-V and the upcoming 2017 ZL1 Camaro. But, we don't know if that new nose design is for a mid-model refresh C7Z06, or maybe a track purpose C7Z06, or even a ZR1. But, it shows they are working on that.
How to fix the issues with the current nose? Improve the heat transfer efficiency of the current cooling systems. Increase airflow through the radiator, increase surface area of the radiator, revise the oil cooling layout. Move more air through the engine bay, maybe with lower ducts under the bumper? Add more fluid volume to the systems, to allow them to heat up less quickly? Just random thoughts here, we'll learn soon enough.
#103
I really hope GM is thinking hard on how to make these new parts affordable. The supercharger lid and brick upgrade appears to be $4,500 MSRP based on Ben's thread. That's tough to swallow for maybe increasing timing advance 1 degree on track. Is the profit on these parts what GM normally gets on parts in the service department? As long as we're not getting milked for profit in an unusual manner I'm fine with paying for upgrades. That MSRP seems obnoxious to me. Most supercharger assemblies, in full with rotors and all, are worth that much.
#104
Quite a few here know people that work at GM, and work on the Corvette and Camaro programs. While they aren't necessarily emailing us drawings or photos, they do hint at things sometimes. Here is an example, I knew about the 2017 cooling mods back in 2015. Back when many people here were still in denial that it was a real issue, and that GM wouldn't do anything about it. They knew it had these issues before the first C7Z hit the streets, honest truth.
https://www.corvetteforum.com/forums...post1590598398
Chris
#105
Jeff's response is interesting in a number of ways. It indicates some changes coming for Z51 automatics. That means that we are definitely getting something that is not supercharger related in addition to the SC cover. I imagine this is the upgraded auto trans cooler that Jag polled about a while back.
He also doesn't list any changes coming to Z51 manual cars so perhaps they are just rerating them as good to 100F on the NA cars? If there is additional engine cooling it clearly isn't the secondary radiator as we know it today.
#106
I also posted about a 2.3L (or larger) blower that was spotted in early production, from GM. You can bet it shows up on the ZR1/Zora. It looked identical to the current LT4 unit, but with longer internal rotors.
#108
That should give a significant bump in power if it sees production! It'll need those extra side coolers in the nose.
#110
I tend to believe it. GM may change a blower and other internals, but to start changing body panels on the new 2017 ZO6s would be a blatant admission from GM that not only did they screwed up, but they screwed up pretty bad. They won't change panels. At this point, it is pretty obvious the exterior changes are for the ZR1.
Note the use of the term cooling "improvements." Not cooling "fix" or "remedy," etc.
#111
Received 9,531 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
#112
#113
2015 C7 of the Year
E.T.D. Corvettes (08-24-2016)
#116
So a picture of the Z06 actual VIN (look at its 10th digit showing it is a 2017), a confirming picture from AutoCheck.com that it is a 2017 Z06, and a picture of its exterior showing no changes, and you are sticking with your "story."
I know what we saw, took pictures of, and that's exactly what we posted.
Enjoy the actual upcoming reveal by GM, confirming their are ZERO 2017 exterior changes to the body panels, nor any different nor additional grilles/vents. However, if you wait to place your order for a 2018, you might be right.
#117
You guys still doubt John & Jeremy...
#119
Sorry, but I have to ask. Was over in the C7 section, and someone just came back from Spring Mountain and mentioned that it was 110 degrees on the track.
I would assume that this is about the hottest weather condition for any track that Corvettes are raced in.
Does the Ron Fellows school do anything to the stock Z51's or Z06's to avoid the overheating that members are experiencing? The C7 poster mentioned that they had both M7s and A8s for the school.
Just a thought and no flames please!!!!
#120
IIRC, someone asked the Boys at Spring Mtn. about this, but didn't get much of an answer.
