C7 Z06 vs Base C7 engine smoothness
I posted yesterday about my new 2016 Z06 and asked the question if the idle is almost as smooth as the base C7. Mine is an A8 and the idle seems a little lumpy and before I bring it back to the dealer I would like to get some feedback and opinions whether this is the way it should be. Thanks in advance for any answers.
Received 2,382 Likes
My Z06 seems a bit rougher as well....I did notice fuel trims are about 20% off at idle, which I thought was weird....
Thought someone mentioned the Z06 has an aggressive cam which makes the idle lumpy.
The Z06 is a little lumpy, but not bad. It's smoother than my wife's 2015 DI Escalade, which the dealer can't get any smoother!
One thing to keep in mind - the OBD2 system monitors the acceleration/deceleration of the crankshaft throughout its rotation so it KNOWS if there was a misfire of any kind, and it will set the Check Engine light for a misfire.
My point? Even if it's a little lumpy at idle, those are NOT misfires if the light's not on, so it's running "right" and I doubt there's anything the dealer can do... it's "supposed" to be that way I imagine unless and until the light is on.
All that said you could have something specific about your car that is causing transmission of a vibration or something, but it's not missing.
I'm kind of beating on this point because it's an important psychological distinction for me - if the car was missing, I want it fixed. If it's just a lumpy idle because of the cam and intake charge reversion, all of that, I'm fine.
It's the nature of the LT4. My Idle is a little rough. At first I was a little concerned, but after reading several related threads/posts, it reassured me of its commonality.
Either it has smooth out a little, or I simply don't notice it anymore...
I remember I could balance a nickel standing up on my LT5 engine.
The Idle Torque tables are set up a little differently from an LT1...I don't mean different, of course they are different, I mean the thought process behind it seems different. Something I intend to look into a bit.
Curious what you mean by that. What happened in 1985?
Engines with bigger cams still will lope a little. Superchargers and VVT have taken the place of big cams for the most part, but I think they still run what they can get away with from a NVH and emissions perspective. No?
LT1 200/207 @ 116.5
LT4 has more duration but less lift.
Does anyone have the duration specs (or better yet valve events) of the LT4 cam?
Found it!!
189/223 on a 120lsa
.492 intake
.551 exhaust
nice work, TA! obviously smaller on the intake side and a wider lobe separation, both would contribute to a better idle so any idle roughness is coming from the longer exhaust duration and the tune.
slingssr (05-09-2016)
It is some what humorous that it seems that most of the new Z06 owners were not owners of the big block power of the old days. Back when the 427/435 days, you be lucky it the car would idle below 1000RPM's and the idle was so lumpy, the whole car shook. I as well have a new Z, and it amazes me it idles as smooth as it does with 650Hp & 650 lbs of torque, in fact of a lot of us old guys like the little bump to remind us the power the new Z has.
