Why is Z always in tour mode at start up?
Track mode exhaust - I don't believe is wide open unless under load. My ears tell me it's closed under constant pressure, and only opens on change or increasing pressure. I could be wrong...but it sure sounds like that.
I can understand GM programming it not to stay in track mode but sometimes their programming decisions seem to make little sense. I can leave and start my 2014 ATS in either touring or sport mode but if left in weather mode it restarts in touring mode as I found out the first time I used weather mode in the snow and was expecting the same throttle mapping after stopping for fuel. Going sideways leaving the station made me aware of this questionable programming choice by GM.
My 2016 Z06 usually stays in sport mode except when rougher roads make touring a better choice.
A very good description of the NPP system function is in post 1 of this tread. https://www.corvetteforum.com/forums...ck-result.html
It has been updated over the last two years as new information has been discovered.
I have found that if you turn the car off in track mode it does default back to tour mode.but if you turn it off in sport mode it will fire back up in sport mode and the exhaust will be open and hit hard. you can also do as the others have said and turn the sound management to track mode and the exhaust will stay open all the time no matter which mode your in
track mode is preferred for any speed on the other side of 150+ couldn't pay me to do that in tour or eco mode with that terrible steering setting. plus 4cyl mode....
no need to apologize, (or so it seems in this post) this forum is way too sensitive. Not sure why. Everyone needs to relax and not take every post so seriously.
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,465 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
