Some custom vinyl!!
Nice why to make the car yours! Please post pictures of the white calipers if you go that route. Nitrogen is of course safe but I think a waste. It is most important to make sure the air you use is dry. Moisture in the tire that condenses and evaporates with temperature changes has a far greater effect on pressure than expansion and contraction of a dry gas. Never " top off" your tires at a coin operated pump. Push the valve with your thumb and water mist is likely to shoot out. A compressor at a garage that operates air tools will likely have a dryer to reduce moisture. If you can't get dry air for free than it is worth paying for nitrogen because the same process that removes oxygen from air to "make" nitrogen also removes moisture. Unfortunately there is a lot of "magical thinking" that marketing has created involving the use of nitrogen in tires. Key take away, keep inside of tires dry.
The Z06 emblems really pop now. Nice
In case no ones seen the front view
Too bad no one does any custom emblems for the front and rear emblems because i would of course do white black to follow the theme.
need black lugnuts with black wheels.nice job.
Arctic Blastoff (03-31-2017)
