Front Splash Guards
Front Splash Guards
Am researching front splash guards. I have looked at ACS Composite offerings and Apsis offerings. I have been told the OEM guards from GM are not wide enough to cover the exposed body panels and rear brake duct intake. Anyone have any experience with these or others and can offer some words of wisdom? I have the carbon flash ground effects package. Also, are the rear guards really necessary
I have Z07 stage 3 aero (side skirts) and put on the OEM front and rear splash guards. They do a decent job, but it's not perfect, particularly if you intend to track the car. I still have some pitting on the rear quarters above/in front of the rear wheel.
The C6 Z06's had the same problem---the front tires are wider than the car. End result is that the road debris gets thrown up against the car. Several years ago a Z06 owner told me about the Apsis guards---I have used them ever since and have had no road debris issues at all on 3 Z's and some 25,000 miles. One Z had the side rocker panels, two did not.
Last I read on this Forum was that only the Apsis guards are wider then the tires. Please note, I also do recall one post where someone said they still got damage even with the Apsis guards, but in all the years of reading about this, he seemed to be the exception.
Best of luck to you with this-----it is just a shame GM hasn't properly addressed this after all these years.
I have the ACS guards and no side skirts. At 2000 miles the rear brake ducts still look fine. The ducts do get some mud splashes on them from time to time so I'll assume rocks could still get thrown back there but so far so good. I went with the ACS guards because I like the looks of them better than the Apsis ones.
What kind of money we talking here.
z51vett
Doug
z51vett
Doug
I bought the Apsis ones a couple of weeks ago. They look like they'll do a lot better job protecting than the OEM guards and they're not bad looking.
Here's a thread from the C7 forum from a couple of days ago on the same topic:
http://www.corvetteforum.com/forums/...sh-guards.html
Received 8,961 Likes
Bill
Gm Rears. Put Xpel behind the wheel. there's a small area of paint that will pick up a few chips.
ACS fronts are beautiful in design. Look totally factory and do protect the front edge of the side skirts. But do not go below as Bill states. So far, so good.
I also added the ACS side skirts. This is when I could start hearing all kind of objects being picked up by the tread and thrown underneath the car. Before I didn't hear a lot at all. It's the side skirts keeping the debris from the side of the car.
Here is what happens with ACS Mud Guards and Side Skirts. One picture shows the tire rubber thrown by the front wheel while I was on track last weekend. This is on the right side quarter panel. The other picture shows the ACS Mud Guard and Side Skirt on that side.
If you have ACS Mud Guards and Side Skirts and aren't getting debris hits on the sides of the car you aren't driving fast enough. While I was cleaning the car I found I was getting hits on the door above the crease and I thought the crease stopped that so I only added Expel below the crease. Now I will have to add door protection each time I go to the track or get the Expel coverage over the complete door.
Bill
Bill
I installed the ACS front splash guards and the gm rear splash guards on my stingray over the weekend. The quality of the ACS guards was disappointing. The molding at the bottom is poor, leaving an uneven, rather than clean, line that is visible.
I have ACS splash guards on the front of my Z06 It will help with some debris flying up into the door areas. I have xpel on the rocker panels and up to about the gas cap on the front of the rear quarter panels. I also added small pieces of xpel door edge strip wrapped around the front edge of the black brake vents where the xpel pre cut parts left the edge partly exposed.
I am not a fan of side skirts, but I believe they really are the right answer. If you look at the line from the bottom of the front tire and just under the splash guards you can see that the front tire can throw stones under the splash guards to hit the lower part of the rocker panels and up to about as high as the gas cap on the rear quarter panels. Since I did not go with side skirts I put on the xpel and I am hoping for the best. I just hate the sound of the tires picking up every stone and throwing them into the rocker panels and the brake vent.
I also put on GM rear splash guards (easy to install) because the OEM cover leaves a little of the painted corner exposed behind the tire and once I saw that I decided to add the rear guards and not worry about it getting dinged up.
Good luck.
Good luck.
Bill
Bill
Now, the fit was excellent and they look good but I did think they could be molded a bit "cleaner".
Well you do have to let them know you want a passing signal. If you fall back and ride a couple car lengths back they think you are happy being there. You have to make them think you are going to take the paint off their back bumper. Maybe I am too easy on them. I have Expel on the front fascia, I wonder how well it would hold up to giving them some love taps going down the straight?
Bill
Bill
Bill
Bill
