Actual modification results for procharged C7Z....Yet???
Is there anyone that can confirm Crank, RWHP, Torque & actual ET Results for A8, 2016 C7Z with Procharger, Headers, Cam, & Meth mods??? Have friend that is considering this build but I encouraged him to seek out some actual results and other possible options/choices. He is considering F-1C Procharger, with medium grind on cam, LT Headers with pulley and plug changes, etc. Wondering if Centri Procharger is way to go or maybe should consider different SC and other build options.
Looking for supercharger change results for confirmation $$$ are spent wisely??? He understands tuner is key.
He is looking for 800+ RWHP and good ET times...
Any thoughts...
Any thoughts...
The following 2 users liked this post by SpunkyQ8:
mitchg41 (03-21-2016),
VictorBarron (03-20-2016)
https://www.corvetteforum.com/forums...er-740whp.html
I've been looking high and low for this information. A vendor summed it up best. 750whp and under its not worth the swap. I've only seen two procharged around that power and one won't shift out of 4th gear (A8) .. Would love to see some success stories to validate spending 10k.
be careful
it looks like you are trying to do your due diligence and that is a good thing. my buddy had his c7 z06 converted to a procharger. he has had nothing but problems. shop #1 put it on originally and had some hoses wrong oil or vacuum-not sure.blew oil everywhere. shop #2 corrected that and said part of his issue on lack of power was a cam. they added a cam and new tune, went to track and broke a belt during his first burnout. . back to shop # 2 for better belt . supposedly repaired and 800 plus HP. did not perform well at all. he was thinking the large hose that moves air slipped and was leaking reducing boost. back in shop now trying to get it ready and right for texas mile. car makes great HP on the dyno but I beat him at the track(drag strip ) with much less HP because my car stays together. it may be all to do with installer and tune but seems to be a big headache for him. engine bay looks great and car sounds fantastic but he is very frustrated right now. I hope to hear some good results with a shop name that I can share with him. good luck.
I know that the Yellow Procharged Z06 that was done by AMP did not make any full passes with success or speeds worthy of a Procharger at the Sulpher Springs half mile shootout. It was advertised as 1000 HP to the wheels. F1X with cam and the works..It sounded bad ***, but just did not seem to get up and go very fast. I beat it the first pass with my speed being 154 MPH, and the second pass The AMP C7 Z06 shop car with bolt ons and ported heads beat it.
Then been beat by a stock McLaren mp12 not to mension that mp12s are pretty fast cars yet that thing shouldn't have stood a chance against the Z if those ponies where performing as they should be!
We demand seeing drag strip/track numbers or even vbox comparison from any procharge vendor to prove otherwise that their system is performing as advertised...
There has to be belt slip holding back that car.
Speaking of "dyno queens" here is a local example of a procharged Z making over 800 rwhp
https://www.instagram.com/p/BBDGOvdNAi6/
https://www.instagram.com/p/BCjURK1IJ56/
Former Vendor
due to prochargers losing a lot of torque low and mid end vs a roots set up the high numbers arent making up for it.
WHIPPLE 2.9 has a new blower out now that will fit under the corvette hood talking to them friday this is the unit they will work on to fit the z06s
https://whipplesuperchargers.com/ind...product_id=369
Former Vendor
CMS just posted this one on their FB - https://www.facebook.com/Cunningham-...9721579418404/
741 rwhp/646 tq... but what rpms are those numbers at. If oem blowers are getting high 600s pretty easy and off idle they are making over 600 at 2500 rpms and that procharger doesnt see 600 till 4000 rpms its going to lose. The low end torque of a modded z06 with stock blower modded is brutal. Even if procharger is making 60 more hp the area where the 60 hp comes in at top and the loss of low end torque if wont beat a basic bolt on z06.
i know the procharger guy here said they sold a lot of kits they cant keep them on the shelf.... so out of all those people no one has got 1/4 mile times?
Glad someone gets this!!!
Area under the curve is brutal and makes for a faster setup..
Samething to a lesser degree on camshaft design... Big cam guys that lose races to cars with much smaller cams lol
Thanks for input...
Former Vendor
from there tech guy here.
"Nobody ordering our swap system has any reason to mess around with low boost numbers. Actually EVERY single system that has been ordered/shipped so far has been for F-1A or larger head units, on 15psi of more boost. (One BETA left with a D1SC on 13psi, makes like 720rwhp, but he has already turned it up, and is currently adding a cam to turn it up more)"
Out of all the cars that have the procharger set up Fran here is the only one that made it to the track. 10.6@138 but had shifting problems. post here https://www.corvetteforum.com/forums...arged-c7z.html
Former Vendor
We actually have a A8 car scheduled for late April getting our Stage IV package, F1X system, and E85/meth. I will post up the results once we're finished up! Our manual cars make 1,050 - 1,075 on E85, and 950 - 980 on pump/methanol, but no track results as of yet.
BooSSted (03-21-2016)
Hmmmmm sounds like the folks doing the work were not familiar with what it takes to create a total engine system upgrade for his car. There is a lot more to it that just whipping on a SC and a tune---for most people to create a effective package integration is needed. Everything from the SC to the larger cooling tank for IC system E85 conversion etc...
Where the HP and TQ comes in and how smooth make all the difference in the world when it comes to hooking up! Been there and done that with a tougher application than any car will pose lol...
