Secondary radiator effectiveness for NA engine
Finally a nice warm day to try out the GM secondary radiator. Just got back from a 24 miles canyon run with the ambient temps right at 80F.
Previously at these temps (80F) my engine oil temperatures got to 280-290 very quickly while the coolant temps never exceeded 225F (due to me shutting it down when the oil reached 290) and the A8 transmission temps were near 200F.
Used the first, downhill portion of the drive to warm up the car and its tires. Turned around an climbed back about 6 - 700 feet in elevation gain in dozen miles with mostly 2nd and 3rd gear cornering speeds, holding the engine over 4000 most of the time, all the way to the redline when the roads allowed.
Conclusion: The Secondary Radiator seems nicely effective for the coolant and for the oil temperatures. Highest coolant temps were 201F, highest oil temps were 262F and the highest A8 temps were exactly on 200F. I am happy with the coolant temps, would still prefer to see the oil not higher than 250F even though I am running the 15W-50 Mobil 1 full time. But, what GM promised appears to be quite close (25F reduction in coolant and 15F reduction in engine oil temps.)
So, looks like the oil temps might still be near 280-290 on those near 100F days but, the coolant issues seem to be fixed, at least for my NA car. Take into account that in my driving I had no straights of any kind where speeds could have contributed to increased air flows into the radiator. My highest speeds achieved were right at redline in 3rd gear.
Changes on my car:
DEI heat shield on cat converter.
ZO6 front grill.
30/70 coolant mix
15W-50 Mobil 1
Removed duct between top of radiator and hood vent. Also removed plastic piece mounted under the hood vent.
Vitesse Throttle controller.
Brake ducts.
Z51 shocks
aFe swaybars
fully lowered on factory bolts
aFe CAI
Now, the car handles beautifully and is a TON OF FUN tossing it around those narrow, winding roads. I'd like to believe that my heat issues are fixed as I can probably live with the oil temps over 260F.
Changes on my car:
ZO6 front grill.
30/70 coolant mix
15W-50 Mobil 1
Brake ducts.
Z51 shocks
aFe swaybars
aFe CAI
The following 4 users liked this post by axr6:
Changes on my car:
ZO6 front grill.
30/70 coolant mix
15W-50 Mobil 1
Brake ducts.
Z51 shocks
aFe swaybars
aFe CAI
Changes on my car:
ZO6 front grill.
30/70 coolant mix
15W-50 Mobil 1
Brake ducts.
Z51 shocks
aFe swaybars
aFe CAI
MarioLento (07-10-2021)
Location: Syracuse-Central Square New York Winer of the all Corvette race WGI 8/23!
AXR6 I didn't realize till now you have a non Z. Those were some high temps coming from a non supercharged engine. Kind of says our superchargers are not adding a lot more towards the heat issues.
You should be fine with temps now even on a track although you appear to run dam hard on the street. Here in NY if you get caught doing that one would end up in jail for a week and car towed away!
Great review, you could probably drop our water mix more, we run 10/90. Enjoy your 80's still 40's around here, sucks!
The OP's ride is obviously not a Z06, why is this post on this thread? The NA issue has no direct value to FI folks. Just sayin'.
I purchased the 3" duct setup that you pioneered but, ran out of time in putting the car back together so, all the parts are still there, waiting. As it seems, I may not need it. I also have a 170F thermostat but, given what I had seen today, I may not install that, either.
As far as hard driving vs. speeds; yes, I used to do banzai road racing in the Bay Area hills, many years ago. It was intense and surprisingly open, as far as the LE was concerned. There were often police cars at the gathering spots but, I'd never seen them make an attempt to stop anyone from racing. Seem like they were there to document and pick up the pieces of mostly superbikers that lost it and ran off the canyon roads. :-). In my lightweight (500HP, 2600 lbs) twin-turbo 3rd gen RX-7 never lost a single race to anyone, bike or car!
These days I live in the Sierra Foothills, surrounded by nearly deserted, beautiful but, tight, winding canyon roads. Mostly 2nd, 3rd gear stuff, which means that I am not exceeding the 55 speed limits by truly prohibitive measures. Given all the electronics that the LE have these days it is truly foolish to open up these cars to anything over 100 MPH. Lose licence, car and go to jail. Not worth it. If I do come to a straight section that could accommodate 100+ MPH speeds, I simply lift and back off. A local Sheriff friend once said: "You're the only person I know that slows down on straights and speeds up into the corners".
I used to race in SCCA successfully for decades, AFTER crashing two expensive street cars on racetracks. Following the crashes, no street cars for me on the tracks. Race cars were much less hassle to repair following those (for me) inevitable crashes.
BTW - looks like we're only a few miles away from each other near Folsom. Perhaps you could come up the hills for a nice drive and show me how your ZO6 would be superior to my NA car over my local roads :-). Who knows, you may actually learn some things by looking at a well setup NA car...?
Received 8,958 Likes
Bill
Changes on my car:
ZO6 front grill.
30/70 coolant mix
15W-50 Mobil 1
Brake ducts.
Z51 shocks
aFe swaybars
aFe CAI
Changes on my car:
ZO6 front grill.
30/70 coolant mix
15W-50 Mobil 1
Brake ducts.
Z51 shocks
aFe swaybars
aFe CAI
Yes, the NA engine overheats just about as quickly as the SC engine in the C7. Have to say, however, that I do not have any of the same heating issues in my 5.0, SC Jaguar XKR. I frequent the ZO6 forums because there seem to be a lot more hardcore racers and performance people here as opposed to the NA forums.
Did you know the GMPP secondary radiator was developed by GMPP for the normally aspirated Z51 to be used in a new race series called the Corvette Challenge as well as for SCCA racing of the Z51 in the T1 class, and only the Z51 was highlighted at the GMPP booth at SEMA this year where they introduced the secondary radiator, s shown on 2 Z51's. I don't know GM has ever shown the secondary radiator in a Z06, although it will fit and will help, but no claim that it is a full and final solution for the Z06. All of the new cooling solutions at the GMPP booth were targeted at the NA car with manual transmissions.
I saw a roughly 10 degree drop in coolant temps last weekend with the secondary radiator. This is compared to a slightly cooler day at the same track last November.
The real test won't come until we get some warm weather but mine never went critical on temp when stock.
Likely you did not see as much improvement as I have because you already had the ZO6 front grill, which, per GM, allows 17 percent more air flows. I've just replaced my stock C7 grill with the ZO6 the same time as I added the radiator. I believe that GM claimed the 25F improvement as the result of adding both the secondary radiator AND the ZO6 grill to the Z51.
Thanks for sharing.
The z51 cars can get as hot as the z06 cars. Minus heat soak and whatnot. Typically the z06 cars might get to those temps a little faster. But regardless both can get there.
And to see a drop in the z51 will make me
Believe a z06 will see a drop as well.
I am subscribed for warmer temps as well.
I'll have better data once we get some actual warm weather to compare to last year.
