Kuhmo V720 ACR tires on Z06?
#41
Bumping this back up. Anyone else try the Kumho ACR on their Z06? Looks like they make some amazing grip, just have to deal with the large delta in front/rear diameters 24.9"/27.5"
They are really cheap now on if you're interested, $238 for fronts, $343 for rears on Tire Rack
https://www.tirerack.com/tires/TireS...earDiameter=19
Edited to add: even cheaper on Ebay
#43
The tires are much faster than the driver and I am trying to work up to the grip level they provide. I've run a track day at Thunderhill and another at Laguna Seca, three autox events, and several thousand street miles to date. The only real wear issue I have is from the tire setting down into the front fender and cutting the front passenger outside edge at LS in turn 6. My non-Z07 suspension is too soft to take that turn fast. There's a little cord showing but it's not on the surface so I'm still running them. I also added more F&R camber after the TH track day and they are happier with that.
I put in a 141.3 at LS on a 90 dB day running in Point-By with coasting through turns 5 and 6 for sound and bottoming issues. The chart below shows Max Lat. Gs. for that day. Not bad for street tires with an old man driving.
--Dan
--Dan
Looking at the quote above it looks like Dan had a great track session with these. Be interesting to know how he did it, or is the C7 is more tolerant of size changes than feedback you received?
#44
Kevin Burke a NASA racer has used the v720 ACR on his grand sport without issues
#45
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I'm running a 285/35/18 front and a 355/35/19 rear on my Z for almost a year now with no problems at all. Plenty of dry weather grip and really not to bad in the rain. We had a couple track events scheduled but the virus put a hold on those. They are also super quite at highway speeds.
#47
Pacembellum (05-15-2020)
#48
