Spoiler question
Spoiler question
I have a black 2015 Z06 with non-Z07 package. I'm wanting to upgrade the spoiler to the stage 3 or similar aero package. What is the best option?
Is it possible to purchase/install the factory stage 3 aero from GM? Do you have to remove the existing spoiler or does it bolt on to the existing base?
Paul
Paul
They have what you need and it's genuine GM.
I upgraded my stage 2 to a stage 3.
http://www.cultragfactoryparts.com/
Scraping the splitter.
Paul
Paul
S.
The rear spoiler does not have to be removed to upgrade to the stage 2/3 wickers or install the clear center wickerbill. If you need the 2/3 wickers, they are about ~$170. The center wickerbill is actually a little more at ~$200. If you need just the Z07 stuff GM has a new "package" with both the clear wickerbill and the Z07 splitter end plates. It's around $450.
S.
S.
So to be clear the stage 2 and the stage 3 end extensions are the same part?
Stage 3 is that part including the center wicker bill ?
Thanks!
Thanks!
Both the stage 2 and Z07 cars have the larger rear spoiler wickers on each side. The Z07 cars also get the clear center wickerbill (also bagged and in the car unless installed during PDI).
Rick Conti best described it in pictures.
http://www.corvetteconti.com/blog/?p=22795
GM offers the Z07 parts in an accessory package now for ~$450.
S.
So the stage 2 and Z07 side wickers are different? Thanks, they look the same on Ricks site. I am confused....sorry doh! Thanks.
2014, Yes you are correct. The side/end wickets are exactly the same for both the stage 2 and 3. The addition of the clear (semi) center adjustable section brings the complete stage 3 to the rear spoiler. It sounds more confusing than it is.
2014C7 (12-29-2015)
Former Vendor
Paul
Paul
NEW GM "STAGE 2" REAR SPOILER EXTENSION KIT 2015 CORVETTE Z06 - GM (23256573)
NEW GM 2014-2016 CHEVROLET CORVETTE Z06 REAR SPOILER WICKER BILL
