Want to drive your C7 Z06 in the Winter without issues?
#41
I can see how the 305/35-20, which has an overall diameter of 28.5", can cause rubbing issues and I am also not at all surprised that they rubbed a hole in the liner.
Yes, using a 28.5" rear tire and a 26.0" front tire would cause the headlights to point very low
The 305/30-20 has a diameter of 27.3" and will not rub at all. Using a 27.3" tall rear tire along with the 26.5" tall front tire will also keep the on-board electronics much less invasive as well.
While the 305-30-20 specs list a maximum wheel width of 11.5" the tire itself is 12.4" wide. The pictures that I posted are of the 305/30-20 mounted on a 12x20 wheel.
The reason I had thought of this combo is actually based on some real world tire applications.
The 2004 Porsche GT2 uses a 315/30-18 rear tire which also has a maximum wheel width of 11.5". The Porsche installed factory wheel is a 18x12.
That reaching beyond the RMA specs goes the other way as well. The 1995 BMW M3 came with a 17x7.5 wheel but the OE tire size of 235/40-17 minimum wheel width is 8.0".
hope that this has answered all of your questions ... if not feel free to post any additional thoughts.
Thanks,
Luke
Thanks,
Luke
Just ordered these from Luke, thank you very much Luke it was a pleasure to talk with you. It is refreshing to deal with a smart friendly person who knows his stuff - Mark
Size & Description Qty Availability Price Each Item Total
305/30R-20 PIRELLI WINTER SOTTOZERO 3 XL
DOWNLOAD WARRANTY BROCHURE PDF
2 In Stock $438.62 $877.24
RETAIL TIRE REGISTRATION CARD
1 In Stock N/C N/C
BASIC LIMITED WARRANTY
1 In Stock N/C N/C
275/35R-19 PIRELLI WINTER SOTTOZERO 3
2 In Stock $316.19 $632.38
Tire Rack Road Hazard Protection Included ($49.26 value. Exclusions apply.) $0.00
1 In Stock N/C N/C
1 In Stock N/C N/C
Track
#43
Luke,
What is the difference in diameter of the OEM front tires on the Z06 (285 30ZR 19 at 26.5") and the Pirelli 275 35R 19 which you recommend. Your website does not list the diameter of the Pirelli's.
I agree that the rears ( .7" difference) hopefully should not rub, (do you know this for sure?) but is there any concern about the front tires rubbing being 35 R height (Pirelli's) as compared to oem Michelin 30 R height?
I want to get it right this time.
Thank you.
Thank you.
#44
Former Vendor
the 285/30-19 Michelin Runflat is 25.8
the 275/35-19 Pirelli SottoZero 3 is 26.5"
I know of several people using these sizes right now with zero issues
#46
#47
as can be seen by the various postings here, there are varying "types" of owners, those that have the Vette as a daily driver and those who have them as garage queens, those that drive them in the winter and those that don't, those that don't mind them getting rained on and those that do... the only question I have is.. should we mount these winter tires on Chrome or Black rims??? I'M KIDDING!!!!!
Good one...
#49
Former Vendor
I would never drive this car in the snow even with winter/snow tires. But on each of my last 911s, I bought a set of winter wheels/tires and mounted them about this time of the year. The Pirelli summer tires are just terrible when the temps dip below 50. Even with AWD on my 911 Turbo, the wheels would lose traction at the top of 1st. By switching to winter rubber, I had more grip.
I imagine that the PSC2 tires are probably even worse than the Pirelli P Zero tires on my 911s, in which case Zs are probably breaking traction much more easily.
I could have taken my 911 Turbo out in the winter on a perfect day with no road salt on the stock Pirelli tires and enjoyed it with a bit of caution. Can the same be done on a 40 degree day with a Z06? Would I light up the rears or risk bringing the tail around on a dry road?
#51
Received 1,992 Likes
Yes you would light it up and break it loose. AND I have posted before that is only half the challenge. Imagine a panic stop!!!! People seem to forget about that side.
As an example my Z51 '14 would break traction hitting 4th gear say in 30 degrees.
Thats why I run a set of contis in cool and snowie weather.
#52
Agree with you.. Why ruin a great looking car with chips everywhere.
#53
#54
#55
I thought these tires would fit on the stock size wheels? In that case why not pick up a set of the $1500 cup wheels from DocZ?
#56
Supporting Vendor - Supporting Member
We have several customer runs the Pirelli Winter tires on our OEM GM cup wheels. The red C7 Z06 below shows how they will look.I belive he ran a 295 or a 305 upfront and a 315 on the rear, cant recall off-hand as it was back in February. Contact member preacher man who posted in our sales thread below for the actual tire sizes.
OEM GM CUP WHEELS FOR 2015-2016 Z06/Z07
https://www.corvetteforum.com/forums...0-per-set.html
#57
Leeds.io
St. Jude Donor '14-'15-'16
I'm thinking of pulling the trigger on these. My concern is that the 305/30/20 in the rear is listed to only fit a 10.5-11.5 inch wheel while the Z wheel is 12". This is why I went with 305/35/20 last year but they ended up rubbing because the listed diameter was wrong.
Anyone running these? Happy with them? I've got a lowered on stock bolts Z07. I don't feel like dropping another 2k on winter tires that don't fit perfectly.
Thanks!
Best,
Gene
Thanks!
Best,
Gene
flyAA (12-02-2015)
#58
Former Vendor
Leeds.io
Let me know. If you can convince me it's safe I'd love to order a set today. It's finally starting to get cold around here.
Best,
Gene
#60
Former Vendor
While the 305-30-20 specs list a maximum wheel width of 11.5" the tire itself is 12.4" wide. The pictures that I posted are of the 305/30-20 mounted on a 20x12 wheel.
That reaching beyond the RMA specs goes the other way as well. The 1995 BMW M3 came with a 17x7.5 wheel but the OE tire size of 235/40-17 has a minimum wheel width is 8.0".
Thanks,
Luke
and good news fro anybody following this thread ....
Pirelli has finally been able to loosen up it's strangle hold on the 305/30-20 SottZero 3 and we are airfreighting some into the states. Current estimated arrival for them is the late November/ early December.
use this link if you want to get in line early for your set
